Gazebo Sensors
MagnetometerSensor Class Reference
#include <MagnetometerSensor.hh>
 MagnetometerSensor ()
 constructor
virtual ~MagnetometerSensor ()
 destructor
virtual bool Init () override
math::Vector3d MagneticField () const
 Get the magnetic field vector in body frame.
void SetWorldMagneticField (const math::Vector3d &_field)
 Set the magnetic field vector in world frame.
 Set the world pose of the sensor.
 Update the sensor.
math::Vector3d WorldMagneticField () const
 Get the magnetic field vector in world frame.
 Get the world pose of the sensor.
 destructor
bool EnableMetrics () const
 FrameId.
SensorId Id () const
 Get the sensor's ID.
bool IsActive () const
bool IsTriggered () const
 Get name.
 Get the current pose.
sdf::ElementPtr SDF () const
void SetActive (bool _active)
 Set Frame ID of the sensor.
 Set the parent of the sensor.
 Update the sensor.
double UpdateRate () const
 Sensor ()
 constructor
A magnetometer reports the magnetic field vector
◆ MagnetometerSensor()
constructor
◆ ~MagnetometerSensor()
virtual ~MagnetometerSensor ( )
destructor
◆ HasConnections()
Reimplemented from Sensor.
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ MagneticField()
math::Vector3d MagneticField ( ) const
Magnetic field vector in body frame
◆ SetWorldMagneticField()
void SetWorldMagneticField ( const math::Vector3d &  _field)
[in]_fieldMagnetic field vector in world frame.
◆ SetWorldPose()
[in]_posePose in world frame
◆ Update() [1/3]
[in]_nowThe current time
Implements Sensor.
◆ Update() [2/3]
SetUpdateRate()
Implements Sensor.
◆ Update() [3/3]
const bool  _force
Update the sensor.
Remarks
◆ WorldMagneticField()
math::Vector3d WorldMagneticField ( ) const
◆ WorldPose()
Pose in world frame.
