Gazebo Sensors
NavSatSensor Class Reference
NavSat Sensor Class. More...
#include <NavSatSensor.hh>
 NavSatSensor ()
virtual ~NavSatSensor ()
double Altitude () const
 Get NavSat altitude above sea level.
virtual bool Init () override
const math::Angle & Latitude () const
 Get the latitude of the NavSat, wrapped between +/- 180 degrees.
const math::Angle & Longitude () const
 Get the longitude of the NavSat, wrapped between +/- 180 degrees.
void SetAltitude (double _altitude)
 Set the altitude of the NavSat.
void SetLatitude (const math::Angle &_latitude)
 Set the latitude of the NavSat.
void SetLongitude (const math::Angle &_longitude)
 Set the longitude of the NavSat.
void SetPosition (const math::Angle &_latitude, const math::Angle &_longitude, double _altitude=0.0)
 Easy short hand for setting the position of the sensor.
void SetVelocity (const math::Vector3d &_vel)
 Set the velocity of the NavSat in ENU world frame.
const math::Vector3d & Velocity () const
 Get the velocity of the NavSat sensor in the ENU world frame.
 destructor
bool EnableMetrics () const
 FrameId.
SensorId Id () const
 Get the sensor's ID.
bool IsActive () const
bool IsTriggered () const
 Get name.
 Get the current pose.
sdf::ElementPtr SDF () const
void SetActive (bool _active)
 Set Frame ID of the sensor.
 Set the parent of the sensor.
 Update the sensor.
double UpdateRate () const
 Sensor ()
 constructor
A sensor that reports position and velocity readings over Gazebo Transport using spherical coordinates (latitude / longitude).
By default, it publishes gz::msgs::NavSat messages on the /.../navsat topic.
This sensor assumes the world is using the East-North-Up (ENU) frame.
◆ NavSatSensor()
◆ ~NavSatSensor()
virtual ~NavSatSensor ( )
◆ Altitude()
double Altitude ( ) const
Altitude in meters
◆ HasConnections()
Reimplemented from Sensor.
virtual bool Init ( )
True on success
◆ Latitude()
const math::Angle & Latitude ( ) const
Latitude angle.
◆ Load() [1/2]
◆ Load() [2/2]
◆ Longitude()
const math::Angle & Longitude ( ) const
Longitude angle.
◆ SetAltitude()
void SetAltitude ( double  _altitude)
[in]_altitudealtitude of NavSat in meters
◆ SetLatitude()
void SetLatitude ( const math::Angle &  _latitude)
[in]_latitudeLatitude of NavSat
◆ SetLongitude()
void SetLongitude ( const math::Angle &  _longitude)
[in]_longitudeLongitude of NavSat
◆ SetPosition()
void SetPosition ( const math::Angle &  _latitude,
const math::Angle &  _longitude,
double  _altitude = 0.0
[in]_latitudeLatitude angle.
[in]_longitudeLongitude angle.
[in]_altitudeAltitude in meters; defaults to zero.
◆ SetVelocity()
void SetVelocity ( const math::Vector3d &  _vel)
[in]_velNavSat in meters per second.
[in]_nowThe current time
Implements Sensor.
◆ Velocity()
const math::Vector3d & Velocity ( ) const
Velocity in meters per second
