#include <AirPressureSensor.hh>
| AirPressureSensor () | |
| constructor More... | |
| virtual | ~AirPressureSensor () |
| destructor More... | |
| virtual bool | HasConnections () const override |
| Check if there are any subscribers. More... | |
| double | ReferenceAltitude () const |
| Get the vertical reference altitude. More... | |
| void | SetReferenceAltitude (double _reference) |
| Set the reference altitude. More... | |
| virtual bool | Update (const std::chrono::steady_clock::duration &_now)=0 |
| virtual | ~Sensor () |
| Add a sequence number to a gz::msgs::Header. This function can be called by a sensor that wants to add a sequence number to a sensor message in order to have improved accountability for generated sensor data. More... | |
| FrameId. More... | |
| SensorId | Id () const |
| bool | IsActive () const |
| Get whether the sensor is enabled or not. More... | |
| Get name. More... | |
| Enable or disable the sensor. Disabled sensors will not generate or publish data unless Update is called with the '_force' argument set to true. More... | |
| Manually set the next time the sensor will generate data Useful for accomodating jumps backwards in time as well as specifying updates for non-uniformly updating sensors. More... | |
| Sensor () | |
A sensor that reports air pressure readings.
◆ AirPressureSensor()
constructor
◆ ~AirPressureSensor()
virtual |
destructor
◆ HasConnections()
overridevirtual |
- Returns
- True if there are subscribers, false otherwise
Reimplemented from Sensor.
◆ Init()
overridevirtual |
◆ Load() [1/2]
overridevirtual |
◆ Load() [2/2]
overridevirtual |
◆ ReferenceAltitude()
| double ReferenceAltitude | ( | ) | const |
- Returns
- Verical reference position in meters
◆ SetReferenceAltitude()
| void SetReferenceAltitude | ( | double | _reference | ) |
[in] _ref Verical reference position in meters
◆ Update() [1/3]
overridevirtual |
[in] _now The current time
- Returns
Implements Sensor.
◆ Update() [2/3]
| virtual bool Update |
- Returns
- See also
- SetUpdateRate()
◆ Update() [3/3]
| bool Update |
Update the sensor.
[in] _now The current time [in] _force Force the update to happen even if it's not time
- Returns
- True if the update was triggered (_force was true or _now >= next_update_time) and the sensor's bool Sensor::Update(std::chrono::steady_clock::time_point) function returned true. False otherwise.
- Remarks
- If forced the NextUpdateTime() will be unchanged.
