Gazebo Sensors
DepthCameraSensor Class Reference
#include <DepthCameraSensor.hh>
 DepthCameraSensor ()
 constructor More...
virtual ~DepthCameraSensor ()
 destructor More...
virtual rendering::DepthCameraPtr DepthCamera () const
 Get a pointer to the rendering depth camera. More...
virtual double FarClip () const
 Get image width. More...
bool HasDepthConnections () const
 Check if there are any depth subscribers. More...
bool HasPointConnections () const
 Check if there are any point subscribers. More...
 Get image height. More...
virtual bool Init () override
virtual double NearClip () const
void OnNewDepthFrame (const float *_scan, unsigned int _width, unsigned int _height, unsigned int, const std::string &)
 Depth data callback used to get the data from the sensor. More...
void OnNewRgbPointCloud (const float *_scan, unsigned int _width, unsigned int _height, unsigned int, const std::string &)
 Point cloud data callback used to get the data from the sensor. More...
 CameraSensor ()
 constructor More...
virtual ~CameraSensor ()
 destructor More...
double Baseline () const
bool HasImageConnections () const
 Check if there are any image subscribers. More...
bool HasInfoConnections () const
 Check if there are any info subscribers. More...
 Get the camera optical frame. More...
 Update the sensor. More...
virtual ~RenderingSensor ()
 destructor More...
void Render ()
 destructor More...
bool EnableMetrics () const
std::string FrameId () const
 FrameId. More...
SensorId Id () const
 Get the sensor's ID. More...
bool IsActive () const
std::string Name () const
 Get name. More...
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
void SetActive (bool _active)
std::string Topic () const
double UpdateRate () const
bool AdvertiseInfo ()
 RenderingSensor ()
 constructor More...
 Sensor ()
 constructor More...
This class creates depth image from a Gazebo Rendering scene. The scene must be created in advance and given to Manager::Init(). It offers both a gz-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ DepthCameraSensor()
constructor
◆ ~DepthCameraSensor()
virtual ~DepthCameraSensor ( )
destructor
◆ ConnectImageCallback()
gz::common::ConnectionPtr ConnectImageCallback ( std::function< void(const gz::msgs::Image &)>  _callback)
Remarks
◆ DepthCamera()
virtual rendering::DepthCameraPtr DepthCamera ( ) const
Rendering depth camera
◆ FarClip()
virtual double FarClip ( ) const
Get image width.
width of the image
◆ HasConnections()
◆ HasDepthConnections()
bool HasDepthConnections ( ) const
Todo:
(iche033) Make this function virtual on Harmonic
◆ HasPointConnections()
bool HasPointConnections ( ) const
Todo:
◆ ImageHeight()
Get image height.
height of the image
◆ ImageWidth()
Get image width.
width of the image
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ NearClip()
virtual double NearClip ( ) const
Get image height.
height of the image
◆ OnNewDepthFrame()
void OnNewDepthFrame ( const float *  _scan,
unsigned int  ,
const std::string &
[in]_scanpointer to the data from the sensor
[in]_widthwidth of the depth image
[in]_heightheight of the depth image
[in]_channelbytes used for the depth data
[in]_formatstring with the format
◆ OnNewRgbPointCloud()
void OnNewRgbPointCloud ( const float *  _scan,
unsigned int  ,
const std::string &
[in]_widthwidth of the point cloud image
[in]_heightheight of the point cloud image
[in]_channelbytes used for the point cloud data
◆ SetScene()
[in]_nowThe current time
