| | ForceTorqueSensor () |
| | constructor More...
| virtual | ~ForceTorqueSensor () |
| | destructor More...
| math::Vector3d | Force () const |
| | Get the current joint force. More...
| virtual bool | HasConnections () const override |
| | Check if there are any subscribers. More...
| | Initialize values in the sensor. More...
| | Load the sensor based on data from an sdf::Sensor object. More...
| | Load the sensor with SDF parameters. More...
| math::Quaterniond | RotationChildInSensor () const |
| | Set the rotation of the joint parent relative to the sensor frame. More...
| math::Quaterniond | RotationParentInSensor () const |
| void | SetForce (const math::Vector3d &_force) |
| | Set the force vector in sensor frame and where the force is applied on the child (parent-to-child) More...
| void | SetRotationChildInSensor (const math::Quaterniond &_rotChildInSensor) |
| | Set the rotation of the joint child relative to the sensor frame. More...
| void | SetRotationParentInSensor (const math::Quaterniond &_rotParentInSensor) |
| void | SetTorque (const math::Vector3d &_torque) |
| | Set the torque vector in sensor frame and where the torque is applied on the child (parent-to-child) More...
| math::Vector3d | Torque () const |
| | Get the current joint torque. More...
| | Update the sensor and generate data. More...
| virtual bool | Update (const std::chrono::steady_clock::duration &_now)=0 |
| | Force the sensor to generate data. More...
| | Update the sensor. More...
| virtual | ~Sensor () |
| | destructor More...
| | Add a sequence number to a gz::msgs::Header. This function can be called by a sensor that wants to add a sequence number to a sensor message in order to have improved accountability for generated sensor data. More...
| | Get flag state for enabling performance metrics publication. More...
| | FrameId. More...
| SensorId | Id () const |
| | Get the sensor's ID. More...
| bool | IsActive () const |
| | Get whether the sensor is enabled or not. More...
| | Get name. More...
| | Return the next time the sensor will generate data. More...
| | Get parent link of the sensor. More...
| | Get the current pose. More...
| | Publishes information about the performance of the sensor. This method is called by Update(). More...
| | Get the SDF used to load this sensor. More...
| | Enable or disable the sensor. Disabled sensors will not generate or publish data unless Update is called with the '_force' argument set to true. More...
| | Set flag to enable publishing performance metrics. More...
| | Set Frame ID of the sensor. More...
| | Manually set the next time the sensor will generate data Useful for accomodating jumps backwards in time as well as specifying updates for non-uniformly updating sensors. More...
| | Set the parent of the sensor. More...
| | Update the pose of the sensor. More...
| | Set topic where sensor data is published. More...
| | Set the update rate of the sensor. An update rate of zero means that the sensor is updated every cycle. It's zero by default. \detail Negative rates become zero. More...
| | Get topic where sensor data is published. More...
| | Get the update rate of the sensor. More...
Force Torque Sensor Class.
A force-torque Sensor that reports force and torque applied on a joint.
