#include <LogicalCameraSensor.hh>
| LogicalCameraSensor () | |
| constructor More... | |
| virtual | ~LogicalCameraSensor () |
| destructor More... | |
| double | AspectRatio () const |
| Get the aspect ratio, which is the width divided by height of the near or far planes. More... | |
| double | Far () const |
| Get the far distance. This is the distance from the frustum's vertex to the farthest plane. More... | |
| virtual bool | HasConnections () const override |
| Check if there are any subscribers. More... | |
| gz::math::Angle | HorizontalFOV () const |
| Get the horizontal field of view. The field of view is the angle between the frustum's vertex and the edges of the near or far plane. This value represents the horizontal angle. More... | |
| msgs::LogicalCameraImage | Image () const |
| Get the latest image. An image is an instance of msgs::LogicalCameraImage, which contains a list of detected models. More... | |
| double | Near () const |
| Get the near distance. This is the distance from the frustum's vertex to the closest plane. More... | |
| void | SetModelPoses (std::map< std::string, math::Pose3d > &&_models) |
| Set the models currently in the world. More... | |
| virtual bool | Update (const std::chrono::steady_clock::duration &_now)=0 |
| virtual | ~Sensor () |
| Add a sequence number to a gz::msgs::Header. This function can be called by a sensor that wants to add a sequence number to a sensor message in order to have improved accountability for generated sensor data. More... | |
| FrameId. More... | |
| SensorId | Id () const |
| bool | IsActive () const |
| Get whether the sensor is enabled or not. More... | |
| virtual bool | Load (const sdf::Sensor &_sdf) |
| Get name. More... | |
| Enable or disable the sensor. Disabled sensors will not generate or publish data unless Update is called with the '_force' argument set to true. More... | |
| Manually set the next time the sensor will generate data Useful for accomodating jumps backwards in time as well as specifying updates for non-uniformly updating sensors. More... | |
| Sensor () | |
A logical camera reports locations of objects. This camera finds models within the sensor's frustum and publishes information about the models on the sensor's topic.
◆ LogicalCameraSensor()
constructor
◆ ~LogicalCameraSensor()
virtual |
destructor
◆ AspectRatio()
| double AspectRatio | ( | ) | const |
- Returns
- The frustum's aspect ratio.
◆ Far()
| double Far | ( | ) | const |
- Returns
- Far distance.
◆ HasConnections()
overridevirtual |
- Returns
- True if there are subscribers, false otherwise
Reimplemented from Sensor.
◆ HorizontalFOV()
| gz::math::Angle HorizontalFOV | ( | ) | const |
- Returns
- The field of view.
◆ Image()
| msgs::LogicalCameraImage Image | ( | ) | const |
- Returns
- List of detected models.
◆ Init()
overridevirtual |
◆ Load()
overridevirtual |
◆ Near()
| double Near | ( | ) | const |
- Returns
- Near distance.
◆ SetModelPoses()
| void SetModelPoses | ( | std::map< std::string, math::Pose3d > && | _models | ) |
[in] _models A map of model names to their world pose.
◆ Update() [1/3]
overridevirtual |
[in] _now The current time
- Returns
Implements Sensor.
◆ Update() [2/3]
| virtual bool Update |
- Returns
- See also
- SetUpdateRate()
◆ Update() [3/3]
| bool Update |
Update the sensor.
[in] _now The current time [in] _force Force the update to happen even if it's not time
- Returns
- True if the update was triggered (_force was true or _now >= next_update_time) and the sensor's bool Sensor::Update(std::chrono::steady_clock::time_point) function returned true. False otherwise.
- Remarks
- If forced the NextUpdateTime() will be unchanged.
