#include <MagnetometerSensor.hh>
| MagnetometerSensor () | |
| constructor More... | |
| virtual | ~MagnetometerSensor () |
| destructor More... | |
| virtual bool | HasConnections () const override |
| Check if there are any subscribers. More... | |
| math::Vector3d | MagneticField () const |
| Get the magnetic field vector in body frame. More... | |
| void | SetWorldMagneticField (const math::Vector3d &_field) |
| Set the magnetic field vector in world frame. More... | |
| void | SetWorldPose (const math::Pose3d _pose) |
| Set the world pose of the sensor. More... | |
| virtual bool | Update (const std::chrono::steady_clock::duration &_now)=0 |
| math::Vector3d | WorldMagneticField () const |
| Get the magnetic field vector in world frame. More... | |
| math::Pose3d | WorldPose () const |
| Get the world pose of the sensor. More... | |
| virtual | ~Sensor () |
| Add a sequence number to a gz::msgs::Header. This function can be called by a sensor that wants to add a sequence number to a sensor message in order to have improved accountability for generated sensor data. More... | |
| FrameId. More... | |
| SensorId | Id () const |
| bool | IsActive () const |
| Get whether the sensor is enabled or not. More... | |
| Get name. More... | |
| Enable or disable the sensor. Disabled sensors will not generate or publish data unless Update is called with the '_force' argument set to true. More... | |
| Manually set the next time the sensor will generate data Useful for accomodating jumps backwards in time as well as specifying updates for non-uniformly updating sensors. More... | |
| Sensor () | |
A magnetometer reports the magnetic field vector
◆ MagnetometerSensor()
constructor
◆ ~MagnetometerSensor()
virtual |
destructor
◆ HasConnections()
overridevirtual |
- Returns
- True if there are subscribers, false otherwise
Reimplemented from Sensor.
◆ Init()
overridevirtual |
◆ Load() [1/2]
overridevirtual |
◆ Load() [2/2]
overridevirtual |
◆ MagneticField()
| math::Vector3d MagneticField | ( | ) | const |
- Returns
- Magnetic field vector in body frame
◆ SetWorldMagneticField()
| void SetWorldMagneticField | ( | const math::Vector3d & | _field | ) |
[in] _field Magnetic field vector in world frame.
◆ SetWorldPose()
| void SetWorldPose | ( | const math::Pose3d | _pose | ) |
[in] _pose Pose in world frame
◆ Update() [1/3]
overridevirtual |
[in] _now The current time
- Returns
Implements Sensor.
◆ Update() [2/3]
| virtual bool Update |
- Returns
- See also
- SetUpdateRate()
◆ Update() [3/3]
| bool Update |
Update the sensor.
[in] _now The current time [in] _force Force the update to happen even if it's not time
- Returns
- True if the update was triggered (_force was true or _now >= next_update_time) and the sensor's bool Sensor::Update(std::chrono::steady_clock::time_point) function returned true. False otherwise.
- Remarks
- If forced the NextUpdateTime() will be unchanged.
◆ WorldMagneticField()
| math::Vector3d WorldMagneticField | ( | ) | const |
- Returns
- Magnetic field vector in world frame
◆ WorldPose()
| math::Pose3d WorldPose | ( | ) | const |
- Returns
- Pose in world frame.
