Gazebo Sensors
#include <gz/sensors/Noise.hh>
 Noise (NoiseType _type)
 Constructor. This should not be called directly unless creating an empty noise model. Use NoiseFactory::NewNoiseModel to instantiate a new noise model. More...
virtual ~Noise ()
double Apply (double _in, double _dt=0.0)
 Apply noise to input data value. More...
virtual double ApplyImpl (double _in, double _dt)
 Apply noise to input data value. This gets overriden by derived classes, and called by Apply. More...
virtual void Load (const sdf::Noise &_sdf)
 Load noise parameters from sdf. More...
virtual void Print (std::ostream &_out) const
 Output information about the noise model. More...
virtual void SetCustomNoiseCallback (std::function< double(double, double)> _cb)
 Register a custom noise callback. More...
NoiseType Type () const
 Accessor for NoiseType. More...
◆ Noise()
Noise ( NoiseType  _type)
[in]_typeType of noise model.
◆ ~Noise()
virtual ~Noise ( )
◆ Apply()
double Apply ( double  _in,
double  _dt = 0.0
[in]_inInput data value.
[in]_dtInput data time step.
Data with noise applied.
◆ ApplyImpl()
virtual double ApplyImpl ( double  _in,
double  _dt
Reimplemented in GaussianNoiseModel.
◆ Load()
virtual void Load ( const sdf::Noise &  _sdf)
[in]_sdfSDF Noise DOM object.
Reimplemented in ImageGaussianNoiseModel, and GaussianNoiseModel.
◆ Print()
virtual void Print ( std::ostream &  _out) const
[in]_outOutput stream
Reimplemented in GaussianNoiseModel, and ImageGaussianNoiseModel.
◆ SetCustomNoiseCallback()
virtual void SetCustomNoiseCallback ( std::function< double(double, double)>  _cb)
[in]_cbCallback function for applying a custom noise model. This is useful if users want to use their own noise model from a sensor plugin.
◆ Type()
NoiseType Type ( ) const
Type of noise currently in use.
