Gazebo Sensors
RgbdCameraSensor Class Reference
#include <RgbdCameraSensor.hh>
 RgbdCameraSensor ()
 constructor More...
virtual ~RgbdCameraSensor ()
 destructor More...
bool HasColorConnections () const
 Check if there are color subscribers. More...
bool HasDepthConnections () const
 Check if there are depth subscribers. More...
bool HasPointConnections () const
 Check if there are point cloud subscribers. More...
 Get image height. More...
 Get image width. More...
virtual bool Init () override
 CameraSensor ()
 constructor More...
virtual ~CameraSensor ()
 destructor More...
double Baseline () const
bool HasImageConnections () const
 Check if there are any image subscribers. More...
bool HasInfoConnections () const
 Check if there are any info subscribers. More...
 Get the camera optical frame. More...
 Update the sensor. More...
virtual ~RenderingSensor ()
 destructor More...
void Render ()
 destructor More...
bool EnableMetrics () const
std::string FrameId () const
 FrameId. More...
SensorId Id () const
 Get the sensor's ID. More...
bool IsActive () const
std::string Name () const
 Get name. More...
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
void SetActive (bool _active)
std::string Topic () const
double UpdateRate () const
bool AdvertiseInfo ()
 RenderingSensor ()
 constructor More...
 Sensor ()
 constructor More...
This class creates a few types of sensor data from a Gazebo Rendering scene:
  • RGB image (same as CameraSensor)
  • Depth image (same as DepthCamera)
  • (future / todo) Color point cloud The scene must be created in advance and given to Manager::Init(). It offers both a gz-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ RgbdCameraSensor()
constructor
◆ ~RgbdCameraSensor()
virtual ~RgbdCameraSensor ( )
destructor
◆ HasColorConnections()
bool HasColorConnections ( ) const
Todo:
(iche033) Make this function virtual on Harmonic
◆ HasConnections()
◆ HasDepthConnections()
bool HasDepthConnections ( ) const
Todo:
◆ HasPointConnections()
bool HasPointConnections ( ) const
Todo:
◆ ImageHeight()
Get image height.
height of the image
◆ ImageWidth()
Get image width.
width of the image
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ SetScene()
[in]_nowThe current time
true if the update was successful
