Gazebo Sensors
SegmentationCameraSensor Class Reference
Segmentation camera sensor class. More...
#include <SegmentationCameraSensor.hh>
 SegmentationCameraSensor ()
 constructor More...
virtual ~SegmentationCameraSensor ()
 destructor More...
 Get image height. More...
 Get image width. More...
virtual bool Init () override
void OnNewSegmentationFrame (const uint8_t *_data, unsigned int _width, unsigned int _height, unsigned int _channels, const std::string &_format)
 Segmentation data callback used to get the data from the sensor. More...
rendering::SegmentationCameraPtr SegmentationCamera () const
 Get the rendering segmentation camera. More...
 CameraSensor ()
 constructor More...
virtual ~CameraSensor ()
 destructor More...
double Baseline () const
bool HasImageConnections () const
 Check if there are any image subscribers. More...
bool HasInfoConnections () const
 Check if there are any info subscribers. More...
 Get the camera optical frame. More...
 Update the sensor. More...
virtual ~RenderingSensor ()
 destructor More...
void Render ()
 destructor More...
bool EnableMetrics () const
std::string FrameId () const
 FrameId. More...
SensorId Id () const
 Get the sensor's ID. More...
bool IsActive () const
std::string Name () const
 Get name. More...
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
void SetActive (bool _active)
std::string Topic () const
double UpdateRate () const
bool AdvertiseInfo ()
 RenderingSensor ()
 constructor More...
 Sensor ()
 constructor More...
This class creates segmentation images from a Gazebo Rendering scene. The scene must be created in advance and given to Manager::Init(). It offers both a gz-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ SegmentationCameraSensor()
constructor
◆ ~SegmentationCameraSensor()
virtual ~SegmentationCameraSensor ( )
destructor
◆ ConnectImageCallback()
gz::common::ConnectionPtr ConnectImageCallback ( std::function< void(const gz::msgs::Image &)>  _callback)
Remarks
◆ HasConnections()
◆ ImageHeight()
Get image height.
height of the image
◆ ImageWidth()
Get image width.
width of the image
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ OnNewSegmentationFrame()
void OnNewSegmentationFrame ( const uint8_t *  _data,
const std::string &  _format
[in]_datapointer to the data from the sensor
[in]_widthwidth of the segmentation image
[in]_heightheight of the segmentation image
[in]_channelsnum of channels
[in]_formatstring with the format
◆ SegmentationCamera()
rendering::SegmentationCameraPtr SegmentationCamera ( ) const
Segmentation camera pointer
◆ SetScene()
[in]_nowThe current time
true if the update was successful
