AirPressure Class Reference
A class that handles air pressure changes. More...
#include <AirPressure.hh>
 AirPressure (ComponentInspectorEditor *_inspector)
Q_INVOKABLE void OnAirPressureNoise (double _mean, double _meanBias, double _stdDev, double _stdDevBias, double _dynamicBiasStdDev, double _dynamicBiasCorrelationTime)
 This function is called when a user changes values in the air pressure sensor.
Q_INVOKABLE void OnAirPressureReferenceAltitude (double _referenceAltitude)
 This function is called when a user changes the air pressure reference altitude.
◆ AirPressure()
AirPressure ( ComponentInspectorEditor *  _inspector)
◆ OnAirPressureNoise()
Q_INVOKABLE void OnAirPressureNoise ( double  _mean,
double  _meanBias,
double  _stdDev,
double  _stdDevBias,
[in]_meanMean value
[in]_meanBiasBias mean value
◆ OnAirPressureReferenceAltitude()
Q_INVOKABLE void OnAirPressureReferenceAltitude ( double  _referenceAltitude)
[in]_referenceAltitudeNew reference altitude value.
