Altimeter Class Reference
A class that handles altimeter changes. More...
#include <Altimeter.hh>
 Altimeter (ComponentInspectorEditor *_inspector)
Q_INVOKABLE void OnAltimeterPositionNoise (double _mean, double _meanBias, double _stdDev, double _stdDevBias, double _dynamicBiasStdDev, double _dynamicBiasCorrelationTime)
 This function is called when a user changes values in the altimeter sensor's position noise.
Q_INVOKABLE void OnAltimeterVelocityNoise (double _mean, double _meanBias, double _stdDev, double _stdDevBias, double _dynamicBiasStdDev, double _dynamicBiasCorrelationTime)
 This function is called when a user changes values in the altimeter sensor's velocity noise.
◆ Altimeter()
Altimeter ( ComponentInspectorEditor *  _inspector)
◆ OnAltimeterPositionNoise()
Q_INVOKABLE void OnAltimeterPositionNoise ( double  _mean,
double  _meanBias,
double  _stdDev,
double  _stdDevBias,
[in]_meanMean value
[in]_meanBiasBias mean value
◆ OnAltimeterVelocityNoise()
Q_INVOKABLE void OnAltimeterVelocityNoise ( double  _mean,
double  _meanBias,
double  _stdDev,
double  _stdDevBias,
[in]_meanMean value
