A class that handles IMU sensor changes. More...
#include <Imu.hh>
 Imu (ComponentInspectorEditor *_inspector)
Q_INVOKABLE void OnAngularVelocityXNoise (double _mean, double _meanBias, double _stdDev, double _stdDevBias, double _dynamicBiasStdDev, double _dynamicBiasCorrelationTime)
 This function is called when a user changes values in the Imu sensor's angular velocity X noise values.
Q_INVOKABLE void OnAngularVelocityYNoise (double _mean, double _meanBias, double _stdDev, double _stdDevBias, double _dynamicBiasStdDev, double _dynamicBiasCorrelationTime)
 This function is called when a user changes values in the Imu sensor's angular velocity Y noise values.
Q_INVOKABLE void OnAngularVelocityZNoise (double _mean, double _meanBias, double _stdDev, double _stdDevBias, double _dynamicBiasStdDev, double _dynamicBiasCorrelationTime)
 This function is called when a user changes values in the Imu sensor's angular velocity Z noise values.
Q_INVOKABLE void OnLinearAccelerationXNoise (double _mean, double _meanBias, double _stdDev, double _stdDevBias, double _dynamicBiasStdDev, double _dynamicBiasCorrelationTime)
 This function is called when a user changes values in the Imu sensor's linear acceleration X noise values.
Q_INVOKABLE void OnLinearAccelerationYNoise (double _mean, double _meanBias, double _stdDev, double _stdDevBias, double _dynamicBiasStdDev, double _dynamicBiasCorrelationTime)
 This function is called when a user changes values in the Imu sensor's linear acceleration Y noise values.
Q_INVOKABLE void OnLinearAccelerationZNoise (double _mean, double _meanBias, double _stdDev, double _stdDevBias, double _dynamicBiasStdDev, double _dynamicBiasCorrelationTime)
 This function is called when a user changes values in the Imu sensor's linear acceleration Z noise values.
◆ Imu()
Imu ( ComponentInspectorEditor *  _inspector)
◆ OnAngularVelocityXNoise()
Q_INVOKABLE void OnAngularVelocityXNoise ( double  _mean,
double  _meanBias,
double  _stdDev,
double  _stdDevBias,
[in]_meanMean value
[in]_meanBiasBias mean value
◆ OnAngularVelocityYNoise()
Q_INVOKABLE void OnAngularVelocityYNoise ( double  _mean,
double  _meanBias,
double  _stdDev,
double  _stdDevBias,
[in]_meanMean value
◆ OnAngularVelocityZNoise()
Q_INVOKABLE void OnAngularVelocityZNoise ( double  _mean,
double  _meanBias,
double  _stdDev,
double  _stdDevBias,
[in]_meanMean value
◆ OnLinearAccelerationXNoise()
Q_INVOKABLE void OnLinearAccelerationXNoise ( double  _mean,
double  _meanBias,
double  _stdDev,
double  _stdDevBias,
[in]_meanMean value
◆ OnLinearAccelerationYNoise()
Q_INVOKABLE void OnLinearAccelerationYNoise ( double  _mean,
double  _meanBias,
double  _stdDev,
double  _stdDevBias,
[in]_meanMean value
◆ OnLinearAccelerationZNoise()
Q_INVOKABLE void OnLinearAccelerationZNoise ( double  _mean,
double  _meanBias,
double  _stdDev,
double  _stdDevBias,
[in]_meanMean value
