Magnetometer Class Reference
A class that handles magnetometer changes. More...
#include <Magnetometer.hh>
 Magnetometer (ComponentInspectorEditor *_inspector)
Q_INVOKABLE void OnMagnetometerXNoise (double _mean, double _meanBias, double _stdDev, double _stdDevBias, double _dynamicBiasStdDev, double _dynamicBiasCorrelationTime)
 This function is called when a user changes values in the x noise elements.
Q_INVOKABLE void OnMagnetometerYNoise (double _mean, double _meanBias, double _stdDev, double _stdDevBias, double _dynamicBiasStdDev, double _dynamicBiasCorrelationTime)
 This function is called when a user changes values in the y noise elements.
Q_INVOKABLE void OnMagnetometerZNoise (double _mean, double _meanBias, double _stdDev, double _stdDevBias, double _dynamicBiasStdDev, double _dynamicBiasCorrelationTime)
 This function is called when a user changes values in the z noise elements.
◆ Magnetometer()
Magnetometer ( ComponentInspectorEditor *  _inspector)
◆ OnMagnetometerXNoise()
Q_INVOKABLE void OnMagnetometerXNoise ( double  _mean,
double  _meanBias,
double  _stdDev,
double  _stdDevBias,
[in]_meanMean value
[in]_meanBiasBias mean value
◆ OnMagnetometerYNoise()
Q_INVOKABLE void OnMagnetometerYNoise ( double  _mean,
double  _meanBias,
double  _stdDev,
double  _stdDevBias,
[in]_meanMean value
◆ OnMagnetometerZNoise()
Q_INVOKABLE void OnMagnetometerZNoise ( double  _mean,
double  _meanBias,
double  _stdDev,
double  _stdDevBias,
[in]_meanMean value
