MsgManager Class Reference
Class to handle messages and subscriptions. More...
#include <MsgManager.hh>
 MsgManager ()
 Default constructor.
void AddInbound (const std::string &_address, const msgs::DataframeSharedPtr &_msg)
 Add a new message to the inbound queue.
void AddOutbound (const std::string &_address, const msgs::DataframeSharedPtr &_msg)
 Add a new message to the outbound queue.
bool AddSubscriber (const std::string &_address, const std::string &_modelName, const std::string &_topic)
 Add a new subscriber. It's possible to associate multiple topics to the same address/model pair. However, the same address cannot be attached to multiple models. When all the subscribers are removed, it's possible to bind to this address using a different model.
Registry Copy () const
 Get a copy of the data structure containing subscriptions and data queues.
Registry & Data ()
 Get a mutable reference to the data containing subscriptions and data queues.
const Registry & DataConst () const
 Get an immutable reference to the data containing subscriptions and data queues.
void DeliverMsgs ()
 This function delivers all the messages in the inbound queue to the appropriate subscribers. This function also clears the inbound queue.
bool RemoveInbound (const std::string &_address, const msgs::DataframeSharedPtr &_msg)
 Remove a message from the inbound queue.
bool RemoveOutbound (const std::string &_address, const msgs::DataframeSharedPtr &_msg)
 Remove a message from the outbound queue.
bool RemoveSubscriber (const std::string &_address, const std::string &_topic)
 Remove an existing subscriber.
void Set (const Registry &_newContent)
 Set the data structure containing subscriptions and data queues.
◆ MsgManager()
◆ AddInbound()
void AddInbound ( const std::string &  _address,
const msgs::DataframeSharedPtr &  _msg
[in]_addressThe destination address.
[in]_msgThe message.
◆ AddOutbound()
void AddOutbound ( const std::string &  _address,
[in]_addressThe sender address.
◆ AddSubscriber()
bool AddSubscriber ( const std::string &  _address,
const std::string &  _modelName,
const std::string &  _topic
[in]_addressThe subscriber address.
[in]_modelNameThe model name.
[in]_topicThe subscriber topic.
True if the subscriber was successfully added or false otherwise.
◆ Copy()
Registry Copy ( ) const
A copy of the data.
◆ Data()
Registry & Data ( )
A mutable reference to the data.
◆ DataConst()
const Registry & DataConst ( ) const
A const reference to the data.
◆ DeliverMsgs()
void DeliverMsgs ( )
◆ RemoveInbound()
bool RemoveInbound ( const std::string &  _address,
[in]_msgMessage pointer to remove.
True if the message was removed or false otherwise.
◆ RemoveOutbound()
bool RemoveOutbound ( const std::string &  _address,
◆ RemoveSubscriber()
bool RemoveSubscriber ( const std::string &  _address,
[in]_topicThe Subscriber topic.
True if the subscriber was removed or false otherwise.
◆ Set()
void Set ( const Registry &  _newContent)
[in]_newContentNew content to be set.
