gz::sim::GZ_SIM_VERSION_NAMESPACE::components Namespace Reference
using SemanticDescription = Component< std::string, class SemanticDescriptionTag, serializers::StringSerializer >
 A component that holds the semantic description of an entity. This is meant to be used by systems such as EntitySemantics to assign descriptions to entities. See https://github.com/ros-simulation/simulation_interfaces/blob/1.0.0/msg/EntityInfo.msg.
using SemanticTags = Component< std::vector< std::string >, class SemanticTagsTag, serializers::SemanticTagsSerializer >
 A component that holds the semantic tag of an entity. This is meant to be used by systems such as EntitySemantics to assign tags to entities. See https://github.com/ros-simulation/simulation_interfaces/blob/1.0.0/msg/TagsFilter.msg.
Typedef Documentation
◆ SemanticDescription
using SemanticDescription = Component<std::string, class SemanticDescriptionTag, serializers::StringSerializer>
◆ SemanticTags
using SemanticTags = Component<std::vector<std::string>, class SemanticTagsTag, serializers::SemanticTagsSerializer>
