Namespace for all events. Refer to the EventManager class for more information about events. More...
Typedefs | |
| using | CollectContactSurfaceProperties = gz::common::EventT< void(const Entity &, const Entity &, const math::Vector3d &, const std::optional< math::Vector3d >, const std::optional< math::Vector3d >, const std::optional< double >, const size_t, physics::SetContactPropertiesCallbackFeature::ContactSurfaceParams< Policy > &), struct CollectContactSurfacePropertiesTag > |
This event is called when the physics engine needs to collect what customizations it should do to the surface of a contact point. It is called during the Update phase after collision checking has been finished and before the physics update has happened. The event subscribers are expected to change the params argument. | |
| using | ForceRender = gz::common::EventT< void(void), struct ForceRenderTag > |
| The force render event may be emitted outside the rendering thread to force rendering calls ie. to ensure rendering occurs even if it wasn't seemingly necessary. | |
| using | LoadSdfPlugins = common::EventT< void(Entity, sdf::Plugins), struct LoadPluginsTag > |
Event used to load plugins for an entity into simulation. Pass in the entity which will own the plugins, and an SDF element for the entity, which may contain multiple <plugin> tags. Makre sure that you don't also connect to the LoadPlugins event. | |
| using | Pause = gz::common::EventT< void(bool), struct PauseTag > |
| The pause event can be used to pause or unpause simulation. Emit a value of true to pause simulation, and emit a value of false to unpause simulation. | |
| using | Policy = physics::FeaturePolicy3d |
| using | PostRender = gz::common::EventT< void(void), struct PostRenderTag > |
| The post render event is emitted after rendering updates. The event is emitted in the rendering thread so rendering calls can be made in this event callback. | |
| using | PreRender = gz::common::EventT< void(void), struct PreRenderTag > |
| The pre render event is emitted before rendering updates. The event is emitted in the rendering thread so rendering calls can be made in this event callback. | |
| using | Render = gz::common::EventT< void(void), struct RenderTag > |
| The render event is emitted during rendering updates. The event is emitted in the rendering thread so rendering calls can be made in this event callback. | |
| using | RenderTeardown = gz::common::EventT< void(void), struct RenderTeardownTag > |
| The render teardown event is emitted right before the rendering thread is torn down. The event is emitted in the rendering thread so last minute, cleanup rendering calls can be made in this event callback. | |
| using | SceneUpdate = gz::common::EventT< void(void), struct SceneUpdateTag > |
| The render event is emitted when the scene manager is updated with contents from the ECM. This event is emitted before the PreRender event on the server side in the rendering thread. It is also accessible on the GUI side. | |
| using | Stop = gz::common::EventT< void(void), struct StopTag > |
| The stop event can be used to terminate simulation. Emit this signal to terminate an active simulation. | |
Typedef Documentation
◆ CollectContactSurfaceProperties
| using CollectContactSurfaceProperties = gz::common::EventT< void( const Entity& , const Entity& , const math::Vector3d & , const std::optional<math::Vector3d> , const std::optional<math::Vector3d> , const std::optional<double> , const size_t , physics::SetContactPropertiesCallbackFeature:: ContactSurfaceParams<Policy>& ), struct CollectContactSurfacePropertiesTag> |
◆ ForceRender
| using ForceRender = gz::common::EventT<void(void), struct ForceRenderTag> |
Useful for custom, out-of-tree rendering sensors that need the rendering thread to perform an update.
For example:
◆ LoadSdfPlugins
| using LoadSdfPlugins = common::EventT<void(Entity, sdf::Plugins), struct LoadPluginsTag> |
◆ Pause
| using Pause = gz::common::EventT<void(bool), struct PauseTag> |
For example, to pause simulation use:
◆ Policy
| using Policy = physics::FeaturePolicy3d |
◆ PostRender
| using PostRender = gz::common::EventT<void(void), struct PostRenderTag> |
For example:
◆ PreRender
| using PreRender = gz::common::EventT<void(void), struct PreRenderTag> |
For example:
◆ Render
| using Render = gz::common::EventT<void(void), struct RenderTag> |
For example:
◆ RenderTeardown
| using RenderTeardown = gz::common::EventT<void(void), struct RenderTeardownTag> |
For example:
◆ SceneUpdate
| using SceneUpdate = gz::common::EventT<void(void), struct SceneUpdateTag> |
For example:
◆ Stop
| using Stop = gz::common::EventT<void(void), struct StopTag> |
For example:
