Resource Struct Reference
Resource used to update the ResourceModel. More...
#include <ResourceSpawner.hh>
Public Attributes
bool isDownloaded = false
 Bool to indicate if this model has been downloaded or not, will always be false with local models as it is irrelevant in this case.
bool isFuel = false
 Bool to indicate if this model is fuel or not.
std::string name = ""
 The name of the resource.
std::string owner = ""
 The owner of the resource, if the resource is local, owner will be empty.
std::string sdfPath = ""
 The absolute path to the sdf corresponding to the local model.
std::string thumbnailPath = ""
 The absolute path to the thumbnail of the local model, will be empty if no thumbnail is found.
◆ isDownloaded
◆ isFuel
bool isFuel = false
◆ name
◆ owner
◆ sdfPath
◆ thumbnailPath
