UpdateInfo Struct Reference
Information passed to systems on the update callback. More...
#include <Types.hh>
Public Attributes
std::chrono::steady_clock::duration dt {0}
 Simulation time handled during a single update.
uint64_t iterations {0}
 Total number of elapsed simulation iterations.
bool paused {true}
 True if simulation is paused, which means the simulation time is not currently running, but systems are still being updated. It is the responsibility of a system update appropriately based on the status of paused. For example, a physics systems should not update state when paused is true.
std::chrono::steady_clock::duration realTime {0}
 Total wall clock time elapsed while simulation is running. This will not increase while paused.
std::chrono::steady_clock::duration simTime {0}
 Total time elapsed in simulation. This will not increase while paused.
Todo:
(louise) Update descriptions once reset is supported.
◆ dt
◆ iterations
◆ paused
bool paused {true}
◆ realTime
◆ simTime
