AlignTool.hh
void OnAlignAxis(const QString &_mode)
Callback to update the axis type.
void OnHoveredExited()
Callback to make whenever a hover state is exited on a button.
void AddState(const AlignState &_state)
Callback to add a state to the execution queue.
void Align()
The function call to execute a state from the queue. This function makes rendering calls and should o...
bool eventFilter(QObject *_obj, QEvent *_event) override
void OnHoveredEntered()
Callback to make whenever a hover state is entered on a button.
void Update(const UpdateInfo &_info, EntityComponentManager &_ecm) override
Update callback called every time the system is stepped. This is called at an Ignition transport thre...
rendering::NodePtr TopLevelNode(rendering::ScenePtr &_scene, rendering::NodePtr &_node) const
Returns the top level node of the passed in node within a given scene.
void OnAlignTarget(const QString &_target)
Callback to update the target type.
rendering::VisualPtr TopLevelVisual(rendering::ScenePtr &_scene, rendering::VisualPtr &_visual) const
Returns the top level visual of the passed in visual within a given scene.
void OnReverse(bool _reverse)
Callback to update if the align orientation is reversed.
void UpdateTransparency(const rendering::NodePtr &_node, bool _makeTransparent)
Updates the node to increase its transparency or reset back to its original transparency value,...
void OnAlignConfig(const QString &_mode)
Callback to update the axis config.
void LoadConfig(const tinyxml2::XMLElement *_pluginElem) override
AlignState
Enumeration of the states within the Align Tool.
Definition: AlignTool.hh:33
@ NONE
Indicates the user is currently not utilizing the align tool.
@ RESET
Indicates a reset of the currently placed nodes, only occurs on a hover exit if the align button has ...
@ HOVER
Indicates the user is currently hovering the mouse over an align button.
@ ALIGN_MID
@ ALIGN_MAX
@ ALIGN_MIN
AlignAxis
Enumeration of the axes to be aligned relative to.
Definition: AlignTool.hh:48
Definition: include/gz/sim/Types.hh:39
