Provides buttons for the align tool. More...
#include <AlignTool.hh>
Public Slots
void OnAlign ()
 Callback to the align state the execution queue. More...
void OnAlignAxis (const QString &_mode)
 Callback to update the axis type. More...
void OnAlignConfig (const QString &_mode)
 Callback to update the axis config. More...
void OnAlignTarget (const QString &_target)
 Callback to update the target type. More...
void OnHoveredEntered ()
 Callback to make whenever a hover state is entered on a button. More...
void OnHoveredExited ()
 Callback to make whenever a hover state is exited on a button. More...
void OnReverse (bool _reverse)
 Callback to update if the align orientation is reversed. More...
 AlignTool ()
 ~AlignTool () override
void AddState (const AlignState &_state)
 Callback to add a state to the execution queue. More...
void Align ()
 The function call to execute a state from the queue. This function makes rendering calls and should only be executed within the render thread. More...
rendering::NodePtr TopLevelNode (rendering::ScenePtr &_scene, rendering::NodePtr &_node) const
 Returns the top level node of the passed in node within a given scene. More...
rendering::VisualPtr TopLevelVisual (rendering::ScenePtr &_scene, rendering::VisualPtr &_visual) const
 Returns the top level visual of the passed in visual within a given scene. More...
 Update callback called every time the system is stepped. This is called at an Ignition transport thread, so any interaction with Qt should be done through signals and slots. More...
void UpdateTransparency (const rendering::NodePtr &_node, bool _makeTransparent)
 Updates the node to increase its transparency or reset back to its original transparency value, an opaque call requires a previous transparent call, otherwise, no action will be taken. More...
Configuration
<service> : Set the service to receive align tool requests.
◆ AlignTool()
AlignTool ( )
◆ ~AlignTool()
~AlignTool ( )
◆ AddState()
void AddState ( const AlignState &  _state)
[in]_stateNew state to add by enum AlignState
◆ Align()
void Align ( )
◆ eventFilter()
QEvent *  _event
overrideprotected
◆ LoadConfig()
◆ OnAlign
void OnAlign ( )
slot
◆ OnAlignAxis
void OnAlignAxis ( const QString &  _mode)
slot
[in]_modeNew axis type
◆ OnAlignConfig
void OnAlignConfig ( const QString &  _mode)
slot
[in]_modeNew config type
◆ OnAlignTarget
void OnAlignTarget ( const QString &  _target)
slot
[in]_targetNew target type
◆ OnHoveredEntered
void OnHoveredEntered ( )
slot
◆ OnHoveredExited
void OnHoveredExited ( )
slot
◆ OnReverse
void OnReverse ( bool  _reverse)
slot
[in]_reverseThe reverse boolean
◆ TopLevelNode()
rendering::NodePtr TopLevelNode ( rendering::ScenePtr &  _scene,
rendering::NodePtr &  _node
) const
[in]_sceneThe scene to check
[in]_nodeThe node to get the top level node for
◆ TopLevelVisual()
rendering::VisualPtr TopLevelVisual ( rendering::ScenePtr &  _scene,
rendering::VisualPtr &  _visual
) const
[in]_visualThe visual to get the top level visual for
Reimplemented from GuiSystem.
◆ UpdateTransparency()
void UpdateTransparency ( const rendering::NodePtr &  _node,
[in]_nodeThe node to update.
[in]_makeTransparenttrue if updating to increase transparency, false to set back to original transparency values (make more opaque)
