EventManager Class Reference
The EventManager is used to send/receive notifications of simulator events. More...
#include <EventManager.hh>
 EventManager ()=default
 ~EventManager ()=default
template<typename E >
gz::common::ConnectionPtr Connect (const typename E::CallbackT &_subscriber)
 Add a connection to an event. More...
unsigned int ConnectionCount ()
 Get connection count for a particular event Connection count for the event. More...
template<typename E , typename ... Args>
void Emit (Args &&... _args)
 Emit an event signal to connected subscribers. More...
The simulator environment and corresponding systems can either connect to an Event or emit an Event as needed to signal actions that need to occur.
See gz::sim::events for a complete list of events. TODO: if visibility is added here the MSVC is unable to compile it. The use of smart pointer inside the unordered_map (events method) is the cause of it. Maybe a compiler bug?
◆ EventManager()
EventManager ( )
default
◆ ~EventManager()
~EventManager ( )
default
◆ Connect()
gz::common::ConnectionPtr Connect ( const typename E::CallbackT &  _subscriber)
inline
[in]_subscriberA std::function callback function. The function signature must match that of the event (template parameter E).
A Connection pointer, which will automatically call Disconnect when it goes out of scope.
References std::endl().
◆ ConnectionCount()
unsigned int ConnectionCount ( )
inline
◆ Emit()
void Emit ( Args &&...  _args)
inline
[in]_argsfunction arguments to be passed to the event callbacks. Must match the signature of the event type E.
