This class provides wrappers around entities and components which are more convenient and straight-forward to use than dealing with the EntityComponentManager directly. All the functions provided here are meant to be used with a light entity. More...
#include <ignition/gazebo/Light.hh>
 Light (gazebo::Entity _entity=kNullEntity)
std::optional< double > AttenuationConstant (const EntityComponentManager &_ecm) const
 Get the light attenuation constant value. Light attenuation is not applicable to directional lights. More...
std::optional< double > AttenuationLinear (const EntityComponentManager &_ecm) const
 Get the light attenuation linear value. Light attenuation is not applicable to directional lights. More...
std::optional< double > AttenuationQuadratic (const EntityComponentManager &_ecm) const
 Get the light attenuation quadratic value. Light attenuation is not applicable to directional lights. More...
std::optional< double > AttenuationRange (const EntityComponentManager &_ecm) const
 Get the light attenuation range. Light attenuation is not applicable to directional lights. More...
std::optional< bool > CastShadows (const EntityComponentManager &_ecm) const
 Get whether the light casts shadows. More...
std::optional< math::Color > DiffuseColor (const EntityComponentManager &_ecm) const
 Get the light diffuse color. More...
std::optional< math::Vector3d > Direction (const EntityComponentManager &_ecm) const
 Get the light direction. More...
gazebo::Entity Entity () const
 Get the entity which this Light is related to. More...
std::optional< double > Intensity (const EntityComponentManager &_ecm) const
std::optional< std::stringName (const EntityComponentManager &_ecm) const
 Get the light's unscoped name. More...
std::optional< gazebo::EntityParent (const EntityComponentManager &_ecm) const
 Get the parent entity. This can be a world or a link. More...
std::optional< math::Pose3d > Pose (const EntityComponentManager &_ecm) const
 Get the pose of the light. The pose is given w.r.t the light's parent. which can be a world or a link. More...
void ResetEntity (gazebo::Entity _newEntity)
 Reset Entity to a new one. More...
void SetAttenuationConstant (EntityComponentManager &_ecm, double _value)
 Set attenuation constant value of this light. More...
void SetAttenuationLinear (EntityComponentManager &_ecm, double _value)
 Set attenuation linear value of this light. More...
void SetAttenuationQuadratic (EntityComponentManager &_ecm, double _value)
 Set attenuation quadratic value of this light. More...
void SetAttenuationRange (EntityComponentManager &_ecm, double _range)
 Set attenuation range of this light. More...
void SetCastShadows (EntityComponentManager &_ecm, bool _castShadows)
 Set whether the light casts shadows. More...
void SetDiffuseColor (EntityComponentManager &_ecm, const math::Color &_color)
 Set the diffuse color of this light. More...
void SetDirection (EntityComponentManager &_ecm, const math::Vector3d &_dir)
 Set light direction. Applies to directional lights. More...
void SetIntensity (EntityComponentManager &_ecm, double _value)
 Set light intensity. More...
void SetPose (EntityComponentManager &_ecm, const math::Pose3d &_pose)
 Set the pose of this light. More...
void SetSpecularColor (EntityComponentManager &_ecm, const math::Color &_color)
 Set the specular color of this light. More...
void SetSpotFalloff (EntityComponentManager &_ecm, double _falloff)
 Set fall off value for this light. Applies to spot lights only. More...
void SetSpotInnerAngle (EntityComponentManager &_ecm, const math::Angle &_angle)
 Set inner angle for this light. Applies to spot lights only. More...
void SetSpotOuterAngle (EntityComponentManager &_ecm, const math::Angle &_angle)
 Set outer angle for this light. Applies to spot lights only. More...
std::optional< math::Color > SpecularColor (const EntityComponentManager &_ecm) const
 Get the light specular color. More...
std::optional< double > SpotFalloff (const EntityComponentManager &_ecm) const
 Get the fall off value of light. Applies to spot lights only. More...
std::optional< math::Angle > SpotInnerAngle (const EntityComponentManager &_ecm) const
 Get the inner angle of light. Applies to spot lights only. More...
std::optional< math::Angle > SpotOuterAngle (const EntityComponentManager &_ecm) const
 Get the outer angle of light. Applies to spot lights only. More...
std::optional< std::stringType (const EntityComponentManager &_ecm) const
 Get the light type. More...
 Check whether this light correctly refers to an entity that has a components::Light. More...
For example, given a light's entity, find the value of its name component, one could use the entity-component manager (ecm) directly as follows:
Light light(entity); std::string name = light.Name(ecm);
◆ Light()
Light ( gazebo::Entity  _entity = kNullEntity)
[in]_entityLight entity
◆ AttenuationConstant()
std::optional<double> AttenuationConstant ( const EntityComponentManager _ecm) const
Attenuation constant value of light or nullopt if the entity does not have a components::Light component.
◆ AttenuationLinear()
std::optional<double> AttenuationLinear ( const EntityComponentManager _ecm) const
Attenuation linear value of light or nullopt if the entity does not have a components::Light component.
◆ AttenuationQuadratic()
std::optional<double> AttenuationQuadratic ( const EntityComponentManager _ecm) const
Attenuation quadratic value of light or nullopt if the entity does not have a components::Light component.
◆ AttenuationRange()
std::optional<double> AttenuationRange ( const EntityComponentManager _ecm) const
Attenuation range of light or nullopt if the entity does not have a components::Light component.
◆ CastShadows()
std::optional<bool> CastShadows ( const EntityComponentManager _ecm) const
Cast shadow bool value of light or nullopt if the entity does not have a components::CastShadows component.
◆ DiffuseColor()
std::optional<math::Color> DiffuseColor ( const EntityComponentManager _ecm) const
Diffuse color of the light or nullopt if the entity does not have a components::Light component.
◆ Direction()
std::optional<math::Vector3d> Direction ( const EntityComponentManager _ecm) const
Direction of light or nullopt if the entity does not have a components::Light component.
◆ Entity()
Light entity.
◆ Intensity()
std::optional<double> Intensity ( const EntityComponentManager _ecm) const
Intensity of light or nullopt if the entity does not have a components::Light component.
◆ Name()
std::optional<std::string> Name ( const EntityComponentManager _ecm) const
Light's name or nullopt if the entity does not have a components::Name component
◆ Parent()
std::optional<gazebo::Entity> Parent ( const EntityComponentManager _ecm) const
Parent entity or nullopt if the entity does not have a components::ParentEntity component.
◆ Pose()
std::optional<math::Pose3d> Pose ( const EntityComponentManager _ecm) const
Pose of the light or nullopt if the entity does not have a components::Pose component.
◆ ResetEntity()
void ResetEntity ( gazebo::Entity  _newEntity)
[in]_newEntityNew light entity.
◆ SetAttenuationConstant()
void SetAttenuationConstant ( EntityComponentManager _ecm,
double  _value
[in]_ecmEntity-component manager. Light attenuation is not applicable to directional lights.
[in]_valueAttenuation constant value to set
◆ SetAttenuationLinear()
void SetAttenuationLinear ( EntityComponentManager _ecm,
double  _value
[in]_valueAttenuation linear value to set
◆ SetAttenuationQuadratic()
void SetAttenuationQuadratic ( EntityComponentManager _ecm,
double  _value
[in]_valueAttenuation quadratic value to set
◆ SetAttenuationRange()
void SetAttenuationRange ( EntityComponentManager _ecm,
double  _range
[in]_boolTrue to cast shadows, false to not cast shadows.
◆ SetCastShadows()
void SetCastShadows ( EntityComponentManager _ecm,
bool  _castShadows
◆ SetDiffuseColor()
void SetDiffuseColor ( EntityComponentManager _ecm,
const math::Color &  _color
[in]_colorDiffuse color to set the light to
◆ SetDirection()
void SetDirection ( EntityComponentManager _ecm,
const math::Vector3d &  _dir
[in]_ecmEntity-component manager. and spot lights only.
[in]_dirDirection to set
◆ SetIntensity()
void SetIntensity ( EntityComponentManager _ecm,
double  _value
[in]_valueIntensity value
◆ SetPose()
void SetPose ( EntityComponentManager _ecm,
const math::Pose3d &  _pose
[in]_ecmEntity-component manager. Pose is set w.r.t. the light's parent which can be a world or a link.
[in]_posePose to set the light to.
◆ SetSpecularColor()
void SetSpecularColor ( EntityComponentManager _ecm,
[in]_colorSpecular color to set the light to
◆ SetSpotFalloff()
void SetSpotFalloff ( EntityComponentManager _ecm,
double  _falloff
[in]_fallOffFall off value
◆ SetSpotInnerAngle()
void SetSpotInnerAngle ( EntityComponentManager _ecm,
const math::Angle &  _angle
[in]_angleAngle to set.
◆ SetSpotOuterAngle()
void SetSpotOuterAngle ( EntityComponentManager _ecm,
◆ SpecularColor()
std::optional<math::Color> SpecularColor ( const EntityComponentManager _ecm) const
Specular color of the light or nullopt if the entity does not have a components::Light component.
◆ SpotFalloff()
std::optional<double> SpotFalloff ( const EntityComponentManager _ecm) const
Fall off value of spot light or nullopt if the entity does not have a components::Light component.
◆ SpotInnerAngle()
std::optional<math::Angle> SpotInnerAngle ( const EntityComponentManager _ecm) const
Inner angle of spot light or nullopt if the entity does not have a components::Light component.
◆ SpotOuterAngle()
std::optional<math::Angle> SpotOuterAngle ( const EntityComponentManager _ecm) const
Outer angle of spot light or nullopt if the entity does not have a components::Light component.
◆ Type()
std::optional<std::string> Type ( const EntityComponentManager _ecm) const
Get the light type.
Type of the light or nullopt if the entity does not have a components::LightType component.
◆ Valid()
bool Valid ( const EntityComponentManager _ecm) const
True if it's a valid light in the manager.
