PlotComponent Class Reference
A container of the component data that keeps track of the registered attributes and update their values and their registered charts. More...
#include <Plotting.hh>
 PlotComponent (const std::string &_type, ignition::gazebo::Entity _entity, ComponentTypeId _typeId)
 ~PlotComponent ()
std::map< std::string, std::shared_ptr< gz::gui::PlotData > > Data () const
 Get all attributes of the component. More...
ignition::gazebo::Entity Entity ()
 Get the Component entity ID. More...
bool HasCharts ()
 Check if any of the component attributes has any chart. More...
void RegisterChart (std::string _attribute, int _chart)
 Add a registered chart to the attribute. More...
void SetAttributeValue (std::string _attribute, const double &_value)
 Set a value of specefic component attribute. More...
ComponentTypeId TypeId ()
 Get the Component type ID. More...
void UnRegisterChart (std::string _attribute, int _chart)
 Remove a registered chart from the attribute. More...
◆ PlotComponent()
PlotComponent ( const std::string _type,
[in]_typecomponent data type (Pose3d, Vector3d, double)
[in]_entityentity id of that component
[in]_typeIdtype identifier unique to each component type
◆ ~PlotComponent()
◆ Data()
std::map<std::string, std::shared_ptr<gz::gui::PlotData> > Data ( ) const
◆ Entity()
Entity ID
◆ HasCharts()
bool HasCharts ( )
true if any attribute has a chart false if all attributes are empty from the charts
◆ RegisterChart()
void RegisterChart ( std::string  _attribute,
int  _chart
[in]_attributecomponent attribute to add the chart to it
[in]_chartchart ID to be added to the attribute
◆ SetAttributeValue()
void SetAttributeValue ( std::string  _attribute,
const double &  _value
[in]_attributecomponent attribute to set its value ex : yaw attribute in Pose3d type Component
[in]_valuevalue to be set to the attribute
◆ TypeId()
ComponentTypeId TypeId ( )
component type ID
◆ UnRegisterChart()
void UnRegisterChart ( std::string  _attribute,
int  _chart
[in]_attributecomponent attribute to remove the chart from it
[in]_chartchart ID to be removed from the attribute
