DoorTimer Class Reference
Timer that's used to keep a door open. It has a configurable default wait duration that when exceeded, it calls a function to let the state machine know to transition to the next state. The timer also checks whether the doorway is blocked, in which case it keeps the door open until whatever blocks the doorway moves out of the way. More...
#include <DoorTimer.hh>
 DoorTimer (const std::chrono::steady_clock::duration &_waitDuration)
 ~DoorTimer ()
void Configure (const std::chrono::steady_clock::duration &_startTime, const std::function< void()> &_timeoutCallback)
 Starts the timer and sets the timeout time based on the given start time. More...
void Update (const UpdateInfo &_info, bool _isDoorwayBlocked)
 Checks whether the timer has timed out. More...
◆ DoorTimer()
DoorTimer ( const std::chrono::steady_clock::duration &  _waitDuration)
[in]_waitDurationDuration
◆ ~DoorTimer()
~DoorTimer ( )
void Configure ( const std::chrono::steady_clock::duration &  _startTime,
const std::function< void()> &  _timeoutCallback
[in]_startTimeStart time
[in]_timeoutCallbackFunction to call upon timeout
[in]_infoCurrent simulation step info
[in]_isDoorwayBlockedFlag that indicates whether the doorway is blocked
