gz/sim/ServerConfig.hh
16 */
17 #ifndef GZ_GAZEBO_SERVERCONFIG_HH_
18 #define GZ_GAZEBO_SERVERCONFIG_HH_
20 #include <chrono>
21 #include <list>
22 #include <memory>
23 #include <optional> // NOLINT(*)
24 #include <string>
25 #include <vector>
26 #include <sdf/Element.hh>
27 #include <sdf/Plugin.hh>
28 #include <sdf/Root.hh>
29 #include <gz/sim/config.hh>
30 #include <gz/sim/Export.hh>
31
32 namespace ignition
33 {
34  namespace gazebo
35  {
36  // Inline bracket to help doxygen filtering.
37  inline namespace IGNITION_GAZEBO_VERSION_NAMESPACE {
38  // Forward declarations.
39  class ServerConfigPrivate;
40
45  class IGNITION_GAZEBO_VISIBLE ServerConfig
46  {
48  public: enum class SourceType
49  {
50  // No source specified.
51  kNone,
52
53  // The source is an SDF Root object.
54  kSdfRoot,
55
56  // The source is an SDF file.
57  kSdfFile,
58
59  // The source is an SDF string.
60  kSdfString,
61  };
62
63
64  class PluginInfoPrivate;
71  public: class IGNITION_GAZEBO_VISIBLE PluginInfo
72  {
74  public: PluginInfo();
75
77  public: ~PluginInfo();
78
92  public: PluginInfo(const std::string &_entityName,
93  const std::string &_entityType,
94  const std::string &_filename,
95  const std::string &_name,
96  const sdf::ElementPtr &_sdf);
97
106  public: PluginInfo(const std::string &_entityName,
107  const std::string &_entityType,
108  const sdf::Plugin &_plugin);
109
112  public: PluginInfo(const PluginInfo &_info);
113
117  public: PluginInfo &operator=(const PluginInfo &_info);
118
123  public: const std::string &EntityName() const;
124
129  public: void SetEntityName(const std::string &_entityName);
130
135  public: const std::string &EntityType() const;
136
141  public: void SetEntityType(const std::string &_entityType);
142
147  public: const std::string &Filename() const;
148
155  public: void SetFilename(const std::string &_filename);
156
162  public: const std::string &Name() const;
163
169  public: void SetName(const std::string &_name);
170
175  public: const sdf::ElementPtr &Sdf() const;
176
181  public: void SetSdf(const sdf::ElementPtr &_sdf);
182
185  public: const sdf::Plugin &Plugin() const;
186
189  public: sdf::Plugin &Plugin();
190
193  public: void SetPlugin(const sdf::Plugin &_plugin) const;
194
197  };
198
200  public: ServerConfig();
201
204  public: ServerConfig(const ServerConfig &_config);
205
207  public: ~ServerConfig();
208
216  public: bool SetSdfFile(const std::string &_file);
217
221  public: std::string SdfFile() const;
222
229  public: bool SetSdfString(const std::string &_sdfString);
230
234  public: std::string SdfString() const;
235
240  public: void SetSdfRoot(const sdf::Root &_root) const;
241
245  public: std::optional<sdf::Root> &SdfRoot() const;
246
249  public: void SetUpdateRate(const double &_hz);
250
254  public: std::optional<double> UpdateRate() const;
255
258  public: bool UseLevels() const;
259
262  public: void SetUseLevels(const bool _levels);
263
268  public: bool UseDistributedSimulation() const;
269
276  public: void SetNetworkSecondaries(unsigned int _secondaries);
277
282  public: unsigned int NetworkSecondaries() const;
283
291  public: void SetNetworkRole(const std::string &_role);
292
298  public: std::string NetworkRole() const;
299
302  public: bool UseLogRecord() const;
303
306  public: void SetUseLogRecord(const bool _record);
307
310  public: const std::string LogRecordPath() const;
311
314  public: void SetLogRecordPath(const std::string &_recordPath);
315
318  public: std::chrono::steady_clock::duration LogRecordPeriod() const;
319
322  public: void SetLogRecordPeriod(
323  const std::chrono::steady_clock::duration &_period);
324
327  public: void AddLogRecordTopic(const std::string &_topic);
328
331  public: void ClearLogRecordTopics();
332
337
340  public: const std::string LogPlaybackPath() const;
341
344  public: void SetLogPlaybackPath(const std::string &_playbackPath);
345
348  public: bool LogRecordResources() const;
349
352  public: void SetLogRecordResources(bool _recordResources);
353
357
360  public: void SetLogRecordCompressPath(const std::string &_path);
361
364  public: unsigned int Seed() const;
365
368  public: void SetSeed(unsigned int _seed);
369
373  public: std::optional<std::chrono::steady_clock::duration>
374  UpdatePeriod() const;
375
381  public: const std::string &ResourceCache() const;
382
388  public: void SetResourceCache(const std::string &_path);
389
392  public: const std::string &PhysicsEngine() const;
393
396  public: void SetPhysicsEngine(const std::string &_physicsEngine);
397
400  public: const std::string &RenderEngineServer() const;
401
404  public: const std::string &RenderEngineGui() const;
405
408  public: void SetHeadlessRendering(const bool _headless);
409
412  public: bool HeadlessRendering() const;
413
416  public: void SetRenderEngineServer(
417  const std::string &_renderEngineServer);
418
421  public: void SetRenderEngineGui(const std::string &_renderEngineGui);
422
426  public: void AddPlugin(const PluginInfo &_info);
427
430  public: void AddPlugins(const std::list<PluginInfo> &_plugins);
431
439  public: PluginInfo LogRecordPlugin() const;
440
444  public: PluginInfo LogPlaybackPlugin() const;
445
449  public: const std::list<PluginInfo> &Plugins() const;
450
454  public: ServerConfig &operator=(const ServerConfig &_cfg);
455
462  Timestamp() const;
463
466  public: SourceType Source() const;
467
469  private: std::unique_ptr<ServerConfigPrivate> dataPtr;
470  };
471
476  IGNITION_GAZEBO_VISIBLE
478
483  IGNITION_GAZEBO_VISIBLE
485
502  //
505  //
508  IGNITION_GAZEBO_VISIBLE
509  loadPluginInfo(bool _isPlayback = false);
510  }
511  }
512 }
513
514 #endif
Information about a plugin that should be loaded by the server.
Definition: gz/sim/ServerConfig.hh:72
Set the plugin XML elements associated with this plugin.
sdf::Plugin & Plugin()
Get a mutable version of the SDF plugin information.
PluginInfo(const std::string &_entityName, const std::string &_entityType, const std::string &_filename, const std::string &_name, const sdf::ElementPtr &_sdf)
Constructor with plugin information specified.
Set the name of the interface within the plugin library to load.
const std::string & Name() const
Name of the interface within the plugin library to load.
Set the type of the entity which should receive this plugin. The type is used in conjuction with Enti...
PluginInfo(const std::string &_entityName, const std::string &_entityType, const sdf::Plugin &_plugin)
const std::string & Filename() const
Get the plugin library filename.
const sdf::Plugin & Plugin() const
Get the SDF plugin information.
PluginInfo & operator=(const PluginInfo &_info)
Equal operator.
Copy constructor.
Set the name of the entity which should receive this plugin. The name is used in conjuction with _ent...
const std::string & EntityType() const
Get the entity type which should receive this plugin. The type is used in conjuction with EntityName ...
const sdf::ElementPtr & Sdf() const
Plugin XML elements associated with this plugin.
Set the SDF plugin information.
const std::string & EntityName() const
Get the name of the entity which should receive this plugin. The name is used in conjuction with _ent...
Configuration parameters for a Server. An instance of this object can be used to construct a Server w...
Definition: gz/sim/ServerConfig.hh:46
Set the render engine gui plugin library.
Generate PluginInfo for Log recording based on the internal state of this ServerConfig object:
void SetLogRecordPeriod(const std::chrono::steady_clock::duration &_period)
Set time period to record states.
Set the number of network secondary servers that the primary server should expect....
const std::vector< std::string > & LogRecordTopics() const
Get the topics to record that were added using AddLogRecordTopic.
Set an SDF string to be used by the server.
void AddPlugins(const std::list< PluginInfo > &_plugins)
Add multiple plugins to the simulation.
Get the SDF String that has been set. An empty string will be returned if an SDF string has not been ...
Instruct simulation to attach a plugin to a specific entity when simulation starts.
Set the network role, which is one of [primary, secondary]. If primary is used, then make sure to als...
Get the number of secondary servers that a primary server should expect.
Set the headless mode.
Set the SDF Root DOM object. The sdf::Root object will take precendence over ServerConfig::SdfString(...
The given random seed.
Get whether meshes and material files are recorded.
SourceType
Type of SDF source.
Definition: gz/sim/ServerConfig.hh:49
const std::string & RenderEngineGui() const
Render engine plugin library to load.
Set the path to where simulation resources, such as models downloaded from fuel.gazebosim....
Set the physics engine plugin library.
const std::list< PluginInfo > & Plugins() const
Get all the plugins that should be loaded.
Copy constructor.
Get the type of source.
std::optional< std::chrono::steady_clock::duration > UpdatePeriod() const
Get the update period duration.
Set the random seed.
Get path to place recorded states.
Get whether the server is using the level system.
Get the SDF file that has been set. An empty string will be returned if an SDF file has not been set.
std::optional< sdf::Root > & SdfRoot() const
Get the SDF Root DOM object.
Set whether the server is recording states.
Get the network role. See SetNetworkRole(const std::string &_role) for more information about distrib...
Set whether meshes and material files are recorded.
Set file path to compress log files to.
const std::string & ResourceCache() const
Path to where simulation resources, such as models downloaded from fuel.gazebosim....
Get whether the server is using the distributed sim system.
Add a topic to record.
Get path to recorded states to play back.
std::optional< double > UpdateRate() const
Get the update rate in Hertz.
std::string LogRecordCompressPath() const
Get file path to compress log files to.
Clear topics to record. This will remove all topics set using AddLogRecordTopic.
Set path to place recorded states.
Set an SDF file to be used with the server.
const std::string & PhysicsEngine() const
Physics engine plugin library to load.
Get whether the server is recording states.
const std::string & RenderEngineServer() const
Set path to recorded states to play back.
Get the headless mode.
const std::chrono::time_point< std::chrono::system_clock > & Timestamp() const
Get the timestamp of this ServerConfig. This is the system time when this ServerConfig was created....
Set the update rate in Hertz. Value <=0 are ignored.
void SetRenderEngineServer(const std::string &_renderEngineServer)
Set the render engine server plugin library.
Generate PluginInfo for Log playback based on the internal state of this ServerConfig object:
Get time period to record states.
ServerConfig & operator=(const ServerConfig &_cfg)
Equal operator.
std::list< ServerConfig::PluginInfo > loadPluginInfo(bool _isPlayback=false)
Load plugin information, following ordering.
std::list< ServerConfig::PluginInfo > parsePluginsFromString(const std::string &_str)
Parse plugins from XML configuration string.
std::list< ServerConfig::PluginInfo > parsePluginsFromFile(const std::string &_fname)
Parse plugins from XML configuration file.
