ServerConfig::PluginInfo Class Reference
#include <ServerConfig.hh>
 PluginInfo ()
 Default constructor. More...
 PluginInfo (const PluginInfo &_info)
 Copy constructor. More...
 PluginInfo (const std::string &_entityName, const std::string &_entityType, const sdf::Plugin &_plugin)
 Constructor with plugin information specified. More...
 PluginInfo (const std::string &_entityName, const std::string &_entityType, const std::string &_filename, const std::string &_name, const sdf::ElementPtr &_sdf)
 ~PluginInfo ()
const std::string & EntityName () const
 Get the name of the entity which should receive this plugin. The name is used in conjuction with _entityType to uniquely identify an entity. More...
const std::string & EntityType () const
 Get the entity type which should receive this plugin. The type is used in conjuction with EntityName to uniquely identify an entity. More...
const std::string & Filename () const
 Get the plugin library filename. More...
 Name of the interface within the plugin library to load. More...
PluginInfo & operator= (const PluginInfo &_info)
 Equal operator. More...
sdf::Plugin & Plugin ()
 Get a mutable version of the SDF plugin information. More...
const sdf::Plugin & Plugin () const
 Get the SDF plugin information. More...
const sdf::ElementPtr & Sdf () const
 Plugin XML elements associated with this plugin. More...
void SetEntityName (const std::string &_entityName)
 Set the name of the entity which should receive this plugin. The name is used in conjuction with _entityType to uniquely identify an entity. More...
void SetEntityType (const std::string &_entityType)
 Set the type of the entity which should receive this plugin. The type is used in conjuction with EntityName to uniquely identify an entity. More...
void SetFilename (const std::string &_filename)
void SetName (const std::string &_name)
 Set the name of the interface within the plugin library to load. More...
void SetPlugin (const sdf::Plugin &_plugin) const
 Set the SDF plugin information. More...
void SetSdf (const sdf::ElementPtr &_sdf)
 Set the plugin XML elements associated with this plugin. More...
Currently supports attaching a plugin to an entity given its type and name, but it can't tell apart multiple entities with the same name in different parts of the entity tree.
const std::list<PluginInfo> &Plugins() const
◆ PluginInfo() [1/4]
◆ ~PluginInfo()
~PluginInfo ( )
◆ PluginInfo() [2/4]
PluginInfo ( const std::string &  _entityName,
const std::string &  _entityType,
const std::string &  _filename,
const std::string &  _name,
const sdf::ElementPtr &  _sdf
[in]_entityNameName of the entity which should receive this plugin. The name is used in conjuction with _entityType to uniquely identify an entity.
[in]_entityTypeEntity type which should receive this plugin. The type is used in conjuction with _entityName to uniquely identify an entity.
[in]_filenamePlugin library filename.
[in]_nameName of the interface within the plugin library to load.
[in]_sdfPlugin XML elements associated with this plugin.
Note
This will be deprecated in Gazebo 7 (Garden), please the use sdf::Plugin interface.
◆ PluginInfo() [3/4]
const sdf::Plugin &  _plugin
[in]_pluginSDF Plugin library information.
◆ PluginInfo() [4/4]
PluginInfo ( const PluginInfo &  _info)
Copy constructor.
[in]_infoPlugin to copy.
◆ EntityName()
const std::string& EntityName ( ) const
Entity name.
◆ EntityType()
const std::string& EntityType ( ) const
Entity type string.
◆ Filename()
const std::string& Filename ( ) const
Note
◆ Name()
const std::string& Name ( ) const
Interface name.
Note
◆ operator=()
PluginInfo& operator= ( const PluginInfo &  _info)
Equal operator.
[in]_infoPluginInfo to copy.
Reference to this class.
◆ Plugin() [1/2]
sdf::Plugin& Plugin ( )
The SDF Plugin object.
◆ Plugin() [2/2]
const sdf::Plugin& Plugin ( ) const
◆ Sdf()
const sdf::ElementPtr& Sdf ( ) const
SDF pointer.
Note
◆ SetEntityName()
void SetEntityName ( const std::string &  _entityName)
[in]_entityNameEntity name.
◆ SetEntityType()
void SetEntityType ( const std::string &  _entityType)
[in]_entityTypeEntity type string.
◆ SetFilename()
void SetFilename ( const std::string &  _filename)
[in]_filenameEntity type string.
Note
◆ SetName()
void SetName ( const std::string &  _name)
[in]_nameInterface name.
Note
◆ SetPlugin()
void SetPlugin ( const sdf::Plugin &  _plugin) const
[in]_pluginThe SDF Plugin object to use.
◆ SetSdf()
void SetSdf ( const sdf::ElementPtr &  _sdf)
[in]_sdfSDF pointer, it will be cloned.
Note
