gz/sim/components/SemanticLabel.hh File Reference
#include "gz/sim/Export.hh"
#include "gz/sim/config.hh"
 ignition
 ignition::gazebo
 ignition::gazebo::components
using SemanticLabel = Component< uint32_t, class SemanticLabelTag >
 A component that holds the label of an entity. One example use case of the Label component is with Segmentation & Bounding box sensors to generate dataset annotations. More...
