ignition::gazebo::serializers Namespace Reference
A Serializer class is used to serialize and deserialize a component. It is passed in as the third template parameter to components::Component. Eg. More...
class  AnimationTimeSerializer
class  ComponentToMsgSerializer
 Serialization for that converts components data types to gz::msgs. This assumes that gz::sim::convert<DataType> is defined. More...
class  DefaultSerializer
 Default serializer template to call stream operators only on types that support them. If the stream operator is not available, a warning message is printed. More...
class  DefaultSerializer< components::NoData >
 Specialization of DefaultSerializer for NoData. More...
class  DefaultSerializer< sdf::World >
 Specialize the DefaultSerializer on sdf::World so we can skip serialization TODO(azeey) Do we ever want to serialize this component? More...
class  DetachableJointInfoSerializer
 Serializer for DetachableJointInfo object. More...
class  JointTypeSerializer
class  LevelEntityNamesSerializer
class  LogicalAudioSourcePlayInfoSerializer
 Serializer for components::LogicalAudioSourcePlayInfo object. More...
class  LogicalAudioSourceSerializer
 Serializer for components::LogicalAudioSource object. More...
class  LogicalMicrophoneSerializer
 Serializer for components::LogicalMicrophone object. More...
class  MsgSerializer
 Serializer for components that hold protobuf messages. More...
class  PerformerLevelsSerializer
class  SdfElementSerializer
class  SdfModelSerializer
class  StringSerializer
 Serializer for components that hold std::string. More...
class  TemperatureRangeInfoSerializer
 Serializer for components::TemperatureRangeInfo object. More...
class  VectorDoubleSerializer
 Serializer for components that hold std::vector<double>. More...
class  VectorSerializer
using ActorSerializer = serializers::ComponentToMsgSerializer< sdf::Actor, msgs::Actor >
using AtmosphereSerializer = serializers::ComponentToMsgSerializer< sdf::Atmosphere, msgs::Atmosphere >
using AxisAlignedBoxSerializer = serializers::ComponentToMsgSerializer< math::AxisAlignedBox, msgs::AxisAlignedBox >
using CollisionElementSerializer = serializers::ComponentToMsgSerializer< sdf::Collision, msgs::Collision >
using GeometrySerializer = serializers::ComponentToMsgSerializer< sdf::Geometry, msgs::Geometry >
using InertialSerializer = serializers::ComponentToMsgSerializer< math::Inertiald, msgs::Inertial >
using JointAxisSerializer = serializers::ComponentToMsgSerializer< sdf::JointAxis, msgs::Axis >
using LightSerializer = serializers::ComponentToMsgSerializer< sdf::Light, msgs::Light >
using MaterialSerializer = serializers::ComponentToMsgSerializer< sdf::Material, msgs::Material >
using PhysicsSerializer = serializers::ComponentToMsgSerializer< sdf::Physics, msgs::Physics >
using SceneSerializer = serializers::ComponentToMsgSerializer< sdf::Scene, msgs::Scene >
using SensorSerializer = ComponentToMsgSerializer< sdf::Sensor, msgs::Sensor >
 Common serializer for sensors. More...
using SphericalCoordinatesSerializer = serializers::ComponentToMsgSerializer< math::SphericalCoordinates, msgs::SphericalCoordinates >
Functions
std::ostream & operator<< (std::ostream &_out, const logical_audio::AttenuationFunction &_func)
 Output stream overload for logical_audio::AttenuationFunction. More...
std::ostream & operator<< (std::ostream &_out, const logical_audio::AttenuationShape &_shape)
 Output stream overload for logical_audio::AttenuationShape. More...
std::ostream & operator<< (std::ostream &_out, const std::chrono::steady_clock::duration &_dur)
 Output stream overload for std::chrono::steady_clock::duration. More...
std::istream & operator>> (std::istream &_in, logical_audio::AttenuationFunction &_func)
 Input stream overload for logical_audio::AttenuationFunction. More...
std::istream & operator>> (std::istream &_in, logical_audio::AttenuationShape &_shape)
 Input stream overload for logical_audio::AttenuationShape. More...
std::istream & operator>> (std::istream &_in, std::chrono::steady_clock::duration &_dur)
 Input stream overload for std::chrono::steady_clock::duration. More...
using Geometry = components::Component<sdf::Geometry, GeometryTag,
Component< sdf::Geometry, class GeometryTag, serializers::GeometrySerializer > Geometry
This component holds an entity's geometry.
Definition: gz/sim/components/Geometry.hh:46
serializers::ComponentToMsgSerializer< sdf::Geometry, msgs::Geometry > GeometrySerializer
Definition: gz/sim/components/Geometry.hh:39
A serializer class implements two static functions: Serialize and Deserialize with the following signatures
class ExampleSerializer
public: static std::ostream &Serialize(std::ostream &_out,
const DataType &_data);
public: static std::istream &Deserialize(std::istream &_in,
DataType &_data)
Typedef Documentation
◆ ActorSerializer
using ActorSerializer = serializers::ComponentToMsgSerializer<sdf::Actor, msgs::Actor>
◆ AtmosphereSerializer
using AtmosphereSerializer = serializers::ComponentToMsgSerializer<sdf::Atmosphere, msgs::Atmosphere>
◆ AxisAlignedBoxSerializer
using AxisAlignedBoxSerializer = serializers::ComponentToMsgSerializer<math::AxisAlignedBox, msgs::AxisAlignedBox>
◆ CollisionElementSerializer
using CollisionElementSerializer = serializers::ComponentToMsgSerializer<sdf::Collision, msgs::Collision>
◆ GeometrySerializer
using GeometrySerializer = serializers::ComponentToMsgSerializer<sdf::Geometry, msgs::Geometry>
◆ InertialSerializer
using InertialSerializer = serializers::ComponentToMsgSerializer<math::Inertiald, msgs::Inertial>
◆ JointAxisSerializer
using JointAxisSerializer = serializers::ComponentToMsgSerializer<sdf::JointAxis, msgs::Axis>
◆ LightSerializer
using LightSerializer = serializers::ComponentToMsgSerializer<sdf::Light, msgs::Light>
◆ MaterialSerializer
using MaterialSerializer = serializers::ComponentToMsgSerializer<sdf::Material, msgs::Material>
◆ PhysicsSerializer
using PhysicsSerializer = serializers::ComponentToMsgSerializer<sdf::Physics, msgs::Physics>
◆ SceneSerializer
using SceneSerializer = serializers::ComponentToMsgSerializer<sdf::Scene, msgs::Scene>
◆ SensorSerializer
using SensorSerializer = ComponentToMsgSerializer<sdf::Sensor, msgs::Sensor>
◆ SphericalCoordinatesSerializer
using SphericalCoordinatesSerializer = serializers::ComponentToMsgSerializer<math::SphericalCoordinates, msgs::SphericalCoordinates>
Function Documentation
◆ operator<<() [1/3]
std::ostream& ignition::gazebo::serializers::operator<< ( std::ostream &  _out,
const logical_audio::AttenuationFunction &  _func
inline
◆ operator<<() [2/3]
const logical_audio::AttenuationShape &  _shape
inline
◆ operator<<() [3/3]
const std::chrono::steady_clock::duration &  _dur
inline
◆ operator>>() [1/3]
std::istream& ignition::gazebo::serializers::operator>> ( std::istream &  _in,
inline
◆ operator>>() [2/3]
inline
◆ operator>>() [3/3]
inline
