ComponentInspectorEditor.hh File Reference
#include <map>
#include <memory>
#include <string>
#include <sdf/Material.hh>
#include <sdf/Physics.hh>
#include <sdf/Joint.hh>
#include <gz/math/SphericalCoordinates.hh>
#include <gz/math/Vector3.hh>
#include <gz/sim/gui/GuiSystem.hh>
#include <gz/sim/Types.hh>
#include <gz/msgs/light.pb.h>
#include "Types.hh"
Functions
 Q_DECLARE_METATYPE (ComponentTypeId) namespace gz
Function Documentation
◆ Q_DECLARE_METATYPE()
Q_DECLARE_METATYPE ( ComponentTypeId  )
Generic function to set data.
[in]_itemItem whose data will be set.
[in]_dataData to set.
Specialized to set string data.
Specialized to set light data.
Specialized to set vector data.
Specialized to set Physics data.
Specialized to set Spherical Coordinates data.
Specialized to set boolean data.
Specialized to set integer data.
Specialized to set double data.
Specialized to set stream data.
Specialized to set material data.
Set the unit of a given item.
[in]_itemItem whose unit will be set.
[in]_unitUnit to be displayed, such as 'm' for meters.
Model holding information about components, such as their type and data.
Constructor
Destructor
Static version of roleNames
A hash connecting a unique identifier to a role name.
Add a component type to the inspector.
[in]_typeIdType of component to be added.
Newly created item.
Remove a component type from the inspector.
[in]_typeIdType of component to be removed.
Keep track of items in the tree, according to type ID.
Displays a tree view with all the entities in the world.
Configuration
None
Entity
Type
Type
Type
Locked
Paused
Simulation paused
Nested Model
Constructor
Destructor
Callback in Qt thread when specular changes.
[in]_rSpecularspecular red
[in]_gSpecularspecular green
[in]_bSpecularspecular blue
[in]_aSpecularspecular alpha
[in]_rDiffuseDiffuse red
[in]_gDiffuseDiffuse green
[in]_bDiffuseDiffuse blue
[in]_aDiffuseDiffuse alpha
[in]_attRangeRange attenuation
[in]_attLinearLinear attenuation
[in]_attConstantConstant attenuation
[in]_attQuadraticQuadratic attenuation
[in]_castShadowsSpecify if this light should cast shadows
[in]_directionXX direction of the light
[in]_directionYY direction of the light
[in]_directionZZ direction of the light
[in]_innerAngleInner angle of the spotlight
[in]_outerAngleOuter angle of the spotlight
[in]_falloffFalloff of the spotlight
[in]_intensityIntensity of the light
[in]_typelight type
Callback in Qt thread when physics' properties change.
[in]_stepSizestep size
[in]_realTimeFactorreal time factor
[in]_rAmbientambient red
[in]_gAmbientambient green
[in]_bAmbientambient blue
[in]_aAmbientambient alpha
[in]_rDiffusediffuse red
[in]_gDiffusediffuse green
[in]_bDiffusediffuse blue
[in]_aDiffusediffuse alpha
[in]_rEmissiveemissive red
[in]_gEmissiveemissive green
[in]_bEmissiveemissive blue
[in]_aEmissiveemissive alpha
[in]_typeif type is not empty, opens QColorDialog. The possible types are ambient, diffuse, specular, or emissive.
[in]_currColorused for QColorDialog to show the current color in the open dialog.
Callback in Qt thread when spherical coordinates change.
[in]_surfaceSurface model
[in]_latitudeLatitude in degrees
[in]_longitudeLongitude in degrees
[in]_elevationElevation in meters
[in]_headingHeading in degrees
Get whether the entity is a nested model or not
True if the entity is a nested model, false otherwise
Notify that is nested model property has changed
Get the entity currently inspected.
Entity ID.
Set the entity currently inspected.
[in]_entityEntity ID.
Get the type of entity currently inspected.
Type, such as 'world' or 'model'
Set the type of entity currently inspected.
[in]_typeType, such as 'world' or 'model'.
Notify that entity type has changed
Get whether the inspector is currently locked on an entity.
True for locked
Set whether the inspector is currently locked on an entity.
[in]_lockedTrue for locked.
Get whether simulation is currently paused.
True for paused.
Notify that simulation paused state has changed.
Set whether simulation is currently paused.
[in]_pausedTrue for paused.
Get whether the inspector is currently paused for updates.
True for paused.
Set whether the inspector is currently paused for updates.
Notify that paused has changed.
Callback in Qt thread when an entity is to be added
[in]_entityEntity to add, e.g. box, sphere, cylinder, etc
[in]_typeEntity type, e.g. link, visual, collision, etc
Callback in Qt thread when a joint is to be added
[in]_jointTypeType of joint to add (revolute, fixed, etc)
[in]_parentLinkName of the link to be the parent link
[in]_childLinkName of the link to be the child link
Return the list of availabe links that are suitable for parent links in joints if a model is selected.
List of available links.
Return the list of availabe links that are suitable for child links in joints if a model is selected.
Set the list of availabe links when a model is selected.
[in]_modelLinksList of available links.
Callback to insert a new entity
[in]_meshMesh file to load.
Add a callback that will be executed during the next Update.
[in]_cbThe callback to run.
Register a component creator. A component creator is responsible for selecting the correct QML and setting the appropriate data for a ComponentTypeId.
[in]_idThe component type id to associate with the creation function.
[in]_creatorFnFunction to call in order to create the QML component.
References std::endl(), gzwarn, stringstream::str(), and IsOutStreamable< Stream, DataType >::value.
