#include <map>
#include <memory>
#include <string>
#include <sdf/Material.hh>
#include <sdf/Physics.hh>
#include <gz/math/SphericalCoordinates.hh>
#include <gz/math/Vector3.hh>
#include <gz/transport/Node.hh>
#include <gz/sim/gui/GuiSystem.hh>
#include <gz/sim/Types.hh>
#include "Types.hh"
#include <gz/msgs/light.pb.h>
Functions | |
Q_DECLARE_METATYPE (ComponentTypeId) namespace gz | |
Function Documentation
◆ Q_DECLARE_METATYPE()
Q_DECLARE_METATYPE | ( | ComponentTypeId | ) |
Generic function to set data.
[in] _item Item whose data will be set. [in] _data Data to set.
Specialized to set string data.
Specialized to set light data.
Specialized to set vector data.
Specialized to set Physics data.
Specialized to set Spherical Coordinates data.
Specialized to set boolean data.
Specialized to set integer data.
Specialized to set double data.
Specialized to set stream data.
Specialized to set material data.
Set the unit of a given item.
[in] _item Item whose unit will be set. [in] _unit Unit to be displayed, such as 'm' for meters.
Model holding information about components, such as their type and data.
Constructor
Destructor
Static version of roleNames
- Returns
- A hash connecting a unique identifier to a role name.
Add a component type to the inspector.
[in] _typeId Type of component to be added.
- Returns
- Newly created item.
Remove a component type from the inspector.
[in] _typeId Type of component to be removed.
Keep track of items in the tree, according to type ID.
Displays a tree view with all the entities in the world.
Configuration
None
Entity
Type
Locked
Paused
Nested Model
System display name list
Constructor
Destructor
Add a callback that's called whenever there are updates from the ECM to the view, for a given component type.
[in] _id The component type id [in] _cb Function that's called when there are updates.
Callback in Qt thread when specular changes.
[in] _rSpecular specular red [in] _gSpecular specular green [in] _bSpecular specular blue [in] _aSpecular specular alpha [in] _rDiffuse Diffuse red [in] _gDiffuse Diffuse green [in] _bDiffuse Diffuse blue [in] _aDiffuse Diffuse alpha [in] _attRange Range attenuation [in] _attLinear Linear attenuation [in] _attConstant Constant attenuation [in] _attQuadratic Quadratic attenuation [in] _castShadows Specify if this light should cast shadows [in] _directionX X direction of the light [in] _directionY Y direction of the light [in] _directionZ Z direction of the light [in] _innerAngle Inner angle of the spotlight [in] _outerAngle Outer angle of the spotlight [in] _falloff Falloff of the spotlight [in] _intensity Intensity of the light [in] _type light type [in] _isLightOn is light on [in] _visualizeVisual is visual enabled
Callback in Qt thread when physics' properties change.
[in] _stepSize step size [in] _realTimeFactor real time factor [in] _rAmbient ambient red [in] _gAmbient ambient green [in] _bAmbient ambient blue [in] _aAmbient ambient alpha [in] _rDiffuse diffuse red [in] _gDiffuse diffuse green [in] _bDiffuse diffuse blue [in] _aDiffuse diffuse alpha [in] _rSpecular specular red [in] _gSpecular specular green [in] _bSpecular specular blue [in] _aSpecular specular alpha [in] _rEmissive emissive red [in] _gEmissive emissive green [in] _bEmissive emissive blue [in] _aEmissive emissive alpha [in] _type if type is not empty, opens QColorDialog. The possible types are ambient, diffuse, specular, or emissive. [in] _currColor used for QColorDialog to show the current color in the open dialog.
Callback in Qt thread when spherical coordinates change.
[in] _surface Surface model [in] _latitude Latitude in degrees [in] _longitude Longitude in degrees [in] _elevation Elevation in meters [in] _heading Heading in degrees
Get whether the entity is a nested model or not
- Returns
- True if the entity is a nested model, false otherwise
Notify that is nested model property has changed
Get the entity currently inspected.
- Returns
- Entity ID.
Set the entity currently inspected.
[in] _entity Entity ID.
Get the type of entity currently inspected.
- Returns
- Type, such as 'world' or 'model'
Set the type of entity currently inspected.
[in] _type Type, such as 'world' or 'model'.
Notify that entity type has changed
Get whether the inspector is currently locked on an entity.
- Returns
- True for locked
Set whether the inspector is currently locked on an entity.
[in] _locked True for locked.
Get whether the inspector is currently paused for updates.
- Returns
- True for paused.
Set whether the inspector is currently paused for updates.
[in] _paused True for paused.
Notify that paused has changed.
Name of world entity
- Returns
- World name
Node for communication
- Returns
- Transport node
Query system plugin info.
Get the system plugin display name list
- Returns
- A list of names that are potentially system plugins
Set the system plugin display name list
[in] _systempFilenameList A list of system plugin display names
Notify that system plugin display name list has changed
Callback when a new system is to be added to an entity
[in] _name Name of system [in] _filename Filename of system [in] _innerxml Inner XML content of the system
References std::endl(), gzwarn, stringstream::str(), and IsOutStreamable< Stream, DataType >::value.
