EntityFeatureMap.hh
17
18 #ifndef GZ_SIM_SYSTEMS_PHYSICS_ENTITY_FEATURE_MAP_HH_
19 #define GZ_SIM_SYSTEMS_PHYSICS_ENTITY_FEATURE_MAP_HH_
20
21 #include <tuple>
22 #include <type_traits>
23 #include <unordered_map>
24
25 #include <gz/physics/Entity.hh>
26 #include <gz/physics/FindFeatures.hh>
27 #include <gz/physics/FeatureList.hh>
28 #include <gz/physics/RequestFeatures.hh>
29
30 #include "gz/sim/Entity.hh"
31
32 namespace gz::sim
33 {
34 inline namespace GZ_SIM_VERSION_NAMESPACE {
35 namespace systems::physics_system
36 {
37  // \brief Helper class that associates Gazebo entities with Physics entities
38  // with required and optional features. It can be used to cast a physics
39  // entity with the required features to another physics entity with one of
40  // the optional features. This class was created to keep all physics entities
41  // in one place so that when a gazebo entity is removed, all the mapped
42  // physics entitities can be removed at the same time. This ensures that
43  // reference counts are properly zeroed out in the underlying physics engines
44  // and the memory associated with the physics entities can be freed.
45  //
46  // DEV WARNING: There is an implicit conversion between physics EntityPtr and
47  // std::size_t in gz-physics. This seems also implicitly convert between
48  // EntityPtr and gazebo Entity. Therefore, any member function that takes a
49  // gazebo Entity can accidentally take an EntityPtr. To prevent this, for
50  // every function that takes a gazebo Entity, we should always have an
51  // overload that also takes an EntityPtr with required features. We can do
52  // this because there's a 1:1 mapping between the two in maps contained in
53  // this class.
54  //
55  // \tparam PhysicsEntityT Type of entity, such as World, Model, or Link
56  // \tparam PolicyT Policy of the physics engine (2D, 3D)
57  // \tparam RequiredFeatureList Required features of the physics entity
58  // \tparam OptionalFeatureLists One or more optional feature lists of the
59  // physics entity.
60  template <template <typename, typename> class PhysicsEntityT,
61  typename PolicyT, typename RequiredFeatureList,
62  typename... OptionalFeatureLists>
64  {
67  public: template <typename T>
68  using PhysicsEntityPtr = physics::EntityPtr<PhysicsEntityT<PolicyT, T>>;
69
72
75  public: template <typename T>
76  using HasFeatureList =
77  std::disjunction<std::is_same<T, OptionalFeatureLists>...>;
78
82  private: using ValueType =
85
95  public: template <typename ToFeatureList>
97  EntityCast(sim::Entity _entity) const
98  {
99  // Using constexpr to limit compiler error message to the static_assert
100  // cppcheck-suppress syntaxError
101  if constexpr (!HasFeatureList<ToFeatureList>::value) // NOLINT
102  {
104  "Trying to cast to a FeatureList not included in the "
105  "optional FeatureLists of this map.");
106  return nullptr;
107  }
108  else
109  {
110  using ToEntityPtr = PhysicsEntityPtr<ToFeatureList>;
111  // Has already been cast
112  auto castIt = this->castCache.find(_entity);
113  if (castIt != this->castCache.end())
114  {
115  auto castEntity = std::get<ToEntityPtr>(castIt->second);
116  if (nullptr != castEntity)
117  {
118  return castEntity;
119  }
120  }
121
122  auto reqEntity = this->Get(_entity);
123  if (nullptr == reqEntity)
124  {
125  return nullptr;
126  }
127
128  // Cast
129  auto castEntity = physics::RequestFeatures<ToFeatureList>::From(
130  this->Get(_entity));
131
132  if (castEntity)
133  {
134  std::get<ToEntityPtr>(this->castCache[_entity]) = castEntity;
135  }
136
137  return castEntity;
138  }
139  }
140
149  public: template <typename ToFeatureList>
150  PhysicsEntityPtr<ToFeatureList>
151  EntityCast(const RequiredEntityPtr &_physicsEntity) const
152  {
153  auto gzEntity = this->Get(_physicsEntity);
154  if (kNullEntity == gzEntity)
155  {
156  return nullptr;
157  }
158  return this->EntityCast<ToFeatureList>(gzEntity);
159  }
160
166  public: RequiredEntityPtr Get(const Entity &_entity) const
167  {
168  auto it = this->entityMap.find(_entity);
169  if (it != this->entityMap.end())
170  {
171  return it->second;
172  }
173  return nullptr;
174  }
175
181  public: Entity Get(const RequiredEntityPtr &_physEntity) const
182  {
183  auto it = this->reverseMap.find(_physEntity);
184  if (it != this->reverseMap.end())
185  {
186  return it->second;
187  }
188  return kNullEntity;
189  }
190
197  {
198  auto it = this->physEntityById.find(_id);
199  if (it != this->physEntityById.end())
200  {
201  return it->second;
202  }
203  return nullptr;
204  }
205
210  public: Entity GetByPhysicsId(std::size_t _id) const
211  {
212  auto it = this->entityByPhysId.find(_id);
213  if (it != this->entityByPhysId.end())
214  {
215  return it->second;
216  }
217  return kNullEntity;
218  }
219
225  public: bool HasEntity(const Entity &_entity) const
226  {
227  return this->entityMap.find(_entity) != this->entityMap.end();
228  }
229
235  public: bool HasEntity(const RequiredEntityPtr &_physicsEntity) const
236  {
237  return this->reverseMap.find(_physicsEntity) != this->reverseMap.end();
238  }
239
243  public: void AddEntity(const Entity &_entity,
244  const RequiredEntityPtr &_physicsEntity)
245  {
246  this->entityMap[_entity] = _physicsEntity;
247  this->reverseMap[_physicsEntity] = _entity;
248  this->physEntityById[_physicsEntity->EntityID()] = _physicsEntity;
249  this->entityByPhysId[_physicsEntity->EntityID()] = _entity;
250  }
251
255  public: bool Remove(Entity _entity)
256  {
257  auto it = this->entityMap.find(_entity);
258  if (it != this->entityMap.end())
259  {
260  this->reverseMap.erase(it->second);
261  this->physEntityById.erase(it->second->EntityID());
262  this->entityByPhysId.erase(it->second->EntityID());
263  this->castCache.erase(_entity);
264  this->entityMap.erase(it);
265  return true;
266  }
267  return false;
268  }
269
273  public: bool Remove(const RequiredEntityPtr &_physicsEntity)
274  {
275  auto it = this->reverseMap.find(_physicsEntity);
276  if (it != this->reverseMap.end())
277  {
278  this->entityMap.erase(it->second);
279  this->physEntityById.erase(it->first->EntityID());
280  this->entityByPhysId.erase(it->first->EntityID());
281  this->castCache.erase(it->second);
282  this->reverseMap.erase(it);
283  return true;
284  }
285  return false;
286  }
287
292  {
293  return this->entityMap;
294  }
295
300  {
301  return this->entityMap.size() + this->reverseMap.size() +
302  this->castCache.size() + this->physEntityById.size() +
303  this->entityByPhysId.size();
304  }
305
308
311
315
317  private: std::unordered_map<std::size_t, Entity> entityByPhysId;
318
321  private: mutable std::unordered_map<Entity, ValueType> castCache;
322  };
323
326  template <template <typename, typename> class PhysicsEntityT,
327  typename RequiredFeatureList, typename... OptionalFeatureLists>
328  using EntityFeatureMap3d =
329  EntityFeatureMap<PhysicsEntityT, physics::FeaturePolicy3d,
330  RequiredFeatureList, OptionalFeatureLists...>;
331 }
332 }
333 }
334 #endif
