EntityFeatureMap< PhysicsEntityT, PolicyT, RequiredFeatureList, OptionalFeatureLists > Class Template Reference
#include <EntityFeatureMap.hh>
Public Types
template<typename T >
using HasFeatureList = std::disjunction< std::is_same< T, OptionalFeatureLists >... >
 Checks whether type T is in the OptionalFeatureLists. More...
using PhysicsEntityPtr = physics::EntityPtr< PhysicsEntityT< PolicyT, T > >
 Template that's preset with the class's Policy type. More...
using RequiredEntityPtr = PhysicsEntityPtr< RequiredFeatureList >
 A EntityPtr with made from RequiredFeatureList. More...
void AddEntity (const Entity &_entity, const RequiredEntityPtr &_physicsEntity)
 Add a mapping between gazebo and physics entities. More...
template<typename ToFeatureList >
PhysicsEntityPtr< ToFeatureList > EntityCast (const RequiredEntityPtr &_physicsEntity) const
 Helper function to cast from an entity type with minimum features to an entity with a different set of features. This overload takes a physics entity as input. More...
PhysicsEntityPtr< ToFeatureList > EntityCast (sim::Entity _entity) const
 Helper function to cast from an entity type with minimum features to an entity with a different set of features. When the entity is cast successfully, it is added to an internal cache so that subsequent casts will use the entity from the cache. More...
RequiredEntityPtr Get (const Entity &_entity) const
 Get the physics entity with required features that corresponds to the input Gazebo entity. More...
Entity Get (const RequiredEntityPtr &_physEntity) const
 Get Gazebo entity that corresponds to the physics entity with required features. More...
Entity GetByPhysicsId (std::size_t _id) const
 Get Gazebo entity that corresponds to the physics entity ID. More...
RequiredEntityPtr GetPhysicsEntityPtr (std::size_t _id) const
 Get the physics entity with required features that has a particular ID. More...
bool HasEntity (const Entity &_entity) const
 Check whether there is a physics entity associated with the given Gazebo entity. More...
bool HasEntity (const RequiredEntityPtr &_physicsEntity) const
 Check whether there is a gazebo entity associated with the given physics entity. More...
const std::unordered_map< Entity, RequiredEntityPtr > & Map () const
 Get the map from Gazebo entity to physics entities with required features. More...
bool Remove (const RequiredEntityPtr &_physicsEntity)
 Remove physics entity from all associated maps. More...
bool Remove (Entity _entity)
 Remove entity from all associated maps. More...
std::size_t TotalMapEntryCount () const
 Get the total number of entries in the maps. Only used for testing. More...
Member Typedef Documentation
◆ HasFeatureList
using HasFeatureList = std::disjunction<std::is_same<T, OptionalFeatureLists>...>
Template Parameters
TA FeatureList to search for in OptionalFeatureLists
◆ PhysicsEntityPtr
using PhysicsEntityPtr = physics::EntityPtr<PhysicsEntityT<PolicyT, T> >
Template Parameters
TA FeatureList that is used in creating an EntityPtr
◆ RequiredEntityPtr
using RequiredEntityPtr = PhysicsEntityPtr<RequiredFeatureList>
◆ AddEntity()
void AddEntity ( const Entity &  _entity,
const RequiredEntityPtr &  _physicsEntity
inline
[in]_entityGazebo entity.
[in]_physicsEntityPhysics entity with required feature
◆ EntityCast() [1/2]
PhysicsEntityPtr<ToFeatureList> EntityCast ( const RequiredEntityPtr &  _physicsEntity) const
inline
Template Parameters
ToFeatureListThe list of features of the resulting entity.
[in]_physicsEntityPhysics entity with required features.
Physics entity with features in ToFeatureList. nullptr if the entity can't be found or the physics engine doesn't support the requested feature.
References EntityFeatureMap< PhysicsEntityT, PolicyT, RequiredFeatureList, OptionalFeatureLists >::Get(), and gz::sim::kNullEntity.
◆ EntityCast() [2/2]
PhysicsEntityPtr<ToFeatureList> EntityCast ( sim::Entity  _entity) const
inline
Template Parameters
References EntityFeatureMap< PhysicsEntityT, PolicyT, RequiredFeatureList, OptionalFeatureLists >::Get().
◆ Get() [1/2]
RequiredEntityPtr Get ( const Entity &  _entity) const
inline
If found, returns the corresponding physics entity. Otherwise, nullptr
References unordered_map< K, T >::end(), and unordered_map< K, T >::find().
Referenced by EntityFeatureMap< PhysicsEntityT, PolicyT, RequiredFeatureList, OptionalFeatureLists >::EntityCast().
◆ Get() [2/2]
Entity Get ( const RequiredEntityPtr &  _physEntity) const
inline
[in]_physEntityPhysics entity with required features
If found, returns the corresponding Gazebo entity. Otherwise, kNullEntity
References unordered_map< K, T >::end(), unordered_map< K, T >::find(), and gz::sim::kNullEntity.
◆ GetByPhysicsId()
Entity GetByPhysicsId ( std::size_t  _id) const
inline
[in]_idPhysics entity ID
◆ GetPhysicsEntityPtr()
RequiredEntityPtr GetPhysicsEntityPtr ( std::size_t  _id) const
inline
[in]_idThe ID of the desired physics entity
◆ HasEntity() [1/2]
bool HasEntity ( const Entity &  _entity) const
inline
True if the there is a physics entity associated with the given Gazebo entity
◆ HasEntity() [2/2]
bool HasEntity ( const RequiredEntityPtr &  _physicsEntity) const
inline
[in]_physicsEntityphysics entity with required features.
True if the there is a gazebo entity associated with the given physics entity
◆ Map()
const std::unordered_map<Entity, RequiredEntityPtr>& Map ( ) const
inline
Immumtable entity map
◆ Remove() [1/2]
bool Remove ( const RequiredEntityPtr &  _physicsEntity)
inline
[in]_physicsEntityPhysics entity.
True if the entity was found and removed.
References unordered_map< K, T >::end(), unordered_map< K, T >::erase(), and unordered_map< K, T >::find().
◆ Remove() [2/2]
bool Remove ( Entity  _entity)
inline
◆ TotalMapEntryCount()
std::size_t TotalMapEntryCount ( ) const
inline
Number of entries in all the maps.
References unordered_map< K, T >::size().
