Altimeter Class Reference
A class that handles altimeter changes. More...
#include <Altimeter.hh>
Altimeter (ComponentInspectorEditor *_inspector) | |
Constructor. More... | |
Q_INVOKABLE void | OnAltimeterPositionNoise (double _mean, double _meanBias, double _stdDev, double _stdDevBias, double _dynamicBiasStdDev, double _dynamicBiasCorrelationTime) |
This function is called when a user changes values in the altimeter sensor's position noise. More... | |
Q_INVOKABLE void | OnAltimeterVelocityNoise (double _mean, double _meanBias, double _stdDev, double _stdDevBias, double _dynamicBiasStdDev, double _dynamicBiasCorrelationTime) |
This function is called when a user changes values in the altimeter sensor's velocity noise. More... | |
🔗Altimeter()
explicit |
[in] _inspector The component inspector.
🔗OnAltimeterPositionNoise()
Q_INVOKABLE void OnAltimeterPositionNoise | ( | double | _mean, |
double | _meanBias, | ||
double | _stdDev, | ||
double | _stdDevBias, | ||
double | _dynamicBiasStdDev, | ||
double | _dynamicBiasCorrelationTime | ||
[in] _mean Mean value [in] _meanBias Bias mean value [in] _stdDev Standard deviation value [in] _stdDevBias Bias standard deviation value [in] _dynamicBiasStdDev Dynamic bias standard deviation value [in] _dynamicBiasCorrelationTime Dynamic bias correlation time value
🔗OnAltimeterVelocityNoise()
Q_INVOKABLE void OnAltimeterVelocityNoise | ( | double | _mean, |
