Data structure for updating skeleton animations. More...
#include <SceneManager.hh>
Public Attributes | |
std::string | animationName |
Name of animation to play. This field is set only if the actor is not animated by manually using skeleton transforms. More... | |
bool | followTrajectory = false |
True if trajectory animation is on. More... | |
bool | loop = false |
True if animation is looped. More... | |
math::Matrix4d | rootTransform |
Transform of the root node in the skeleton. The actor's skeleton's root node transform needs to be set if trajectory animation is enabled. This field is set only if the actor is not animated by manually using skeleton transforms. More... | |
std::chrono::steady_clock::duration | time |
Timepoint in the animation. Note that animation time is different from sim time. An actor can have multiple animations. Animation time is associated with current animation that is being played. This value is also adjusted if interpolate_x is enabled. More... | |
common::TrajectoryInfo | trajectory |
Trajectory to be followed. More... | |
bool | valid = false |
True if this animation update data is valid. If false, this update data should be ignored. More... | |
🔗animationName
std::string animationName |
🔗followTrajectory
bool followTrajectory = false |
🔗loop
bool loop = false |
🔗rootTransform
math::Matrix4d rootTransform |
🔗time
std::chrono::steady_clock::duration time |
🔗trajectory
common::TrajectoryInfo trajectory |
🔗valid
bool valid = false |
