The EventManager is used to send/receive notifications of simulator events. More...
#include <EventManager.hh>
| EventManager ()=default | |
| Constructor. More... | |
| ~EventManager ()=default | |
| Destructor. More... | |
| template<typename E > | |
| gz::common::ConnectionPtr | Connect (const typename E::CallbackT &_subscriber) |
| Add a connection to an event. More... | |
| unsigned int | ConnectionCount () |
| Get connection count for a particular event Connection count for the event. More... | |
| template<typename E , typename ... Args> | |
| void | Emit (Args &&... _args) |
| Emit an event signal to connected subscribers. More... | |
The simulator environment and corresponding systems can either connect to an Event or emit an Event as needed to signal actions that need to occur.
See events for a complete list of events. TODO: if visibility is added here the MSVC is unable to compile it. The use of smart pointer inside the unordered_map (events method) is the cause of it. Maybe a compiler bug?
◆ EventManager()
default |
◆ ~EventManager()
default |
◆ Connect()
inline |
[in] _subscriber A std::function callback function. The function signature must match that of the event (template parameter E).
- Returns
- A Connection pointer, which will automatically call Disconnect when it goes out of scope.
References std::endl(), and gzerr.
◆ ConnectionCount()
inline |
◆ Emit()
inline |
[in] _args function arguments to be passed to the event callbacks. Must match the signature of the event type E.
