Translate and rotate links by dragging them with the mouse. Automatically loads the ApplyLinkWrench system. More...
#include <MouseDrag.hh>
Public Slots
void OnSwitchCOM (const bool _checked)
 Callback when COM switch is pressed. More...
Signals
void PosStiffnessChanged ()
 Notify that the translational stiffness changed. More...
void RotStiffnessChanged ()
 Notify that the rotational stiffness changed. More...
 MouseDrag ()
 ~MouseDrag () override
Q_INVOKABLE double PosStiffness () const
 Get the translational stiffness. More...
Q_INVOKABLE double RotStiffness () const
 Get the rotational stiffness. More...
Q_INVOKABLE void SetPosStiffness (double _posStiffness)
 Set the translational stiffness. More...
Q_INVOKABLE void SetRotStiffness (double _rotStiffness)
 Set the rotational stiffness. More...
 Update callback called every time the system is stepped. This is called at a Gazebo Transport thread, so any interaction with Qt should be done through signals and slots. More...
Properties
double posStiffness
 Stiffness of translation mode. More...
double rotStiffness
 Stiffness of rotation mode. More...
Configuration
  • <rotation_stiffness> : Stiffness of rotation mode, defaults to 100
  • <position_stiffness> : Stiffness of translation mode, defaults to 100
◆ MouseDrag()
MouseDrag ( )
◆ ~MouseDrag()
~MouseDrag ( )
◆ eventFilter()
QEvent *  _event
overrideprotected
◆ LoadConfig()
◆ OnSwitchCOM
void OnSwitchCOM ( const bool  _checked)
slot
[in]_checkedTrue if force should be applied to center of mass
◆ PosStiffness()
Q_INVOKABLE double PosStiffness ( ) const
The translational stiffness
◆ PosStiffnessChanged
void PosStiffnessChanged ( )
signal
◆ RotStiffness()
Q_INVOKABLE double RotStiffness ( ) const
The rotational stiffness
◆ RotStiffnessChanged
void RotStiffnessChanged ( )
signal
◆ SetPosStiffness()
Q_INVOKABLE void SetPosStiffness ( double  _posStiffness)
[in]_posStiffnessThe new translational stiffness
◆ SetRotStiffness()
Q_INVOKABLE void SetRotStiffness ( double  _rotStiffness)
[in]_rotStiffnessThe new rotational stiffness
Reimplemented from GuiSystem.
Property Documentation
◆ posStiffness
double posStiffness
readwrite
◆ rotStiffness
double rotStiffness
readwrite
