Provides buttons for translation, rotation, and scale.
More...
#include <TransformControl.hh>
void | OnMode (const QString &_mode) |
| Callback in Qt thread when mode changes. More...
void | OnSnapToGrid () |
| Callback in Qt thread when the snap to grid button is clicked. More...
void | OnSnapUpdate (double _x, double _y, double _z, double _roll, double _pitch, double _yaw, double _scaleX, double _scaleY, double _scaleZ) |
| Sends an event to update the internal snapping values for translation, rotation, and scaling. More...
double | pitchSnap () |
| Callback in Qt thread when the snap to grid button is clicked in order to update custom snap values menu. More...
double | rollSnap () |
double | scaleXSnap () |
double | scaleYSnap () |
double | scaleZSnap () |
double | xSnap () |
double | yawSnap () |
double | ySnap () |
double | zSnap () |
bool | eventFilter (QObject *_obj, QEvent *_event) override |
Configuration
<service> : Set the service to receive transform mode requests.
🔗TransformControl()
🔗~TransformControl()
🔗activateRotate
Notify that rotation has been activated.
🔗activateSelect
Notify that selection has been activated.
🔗activateTranslate
void activateTranslate |
signal |
Notify that translation has been activated.
🔗eventFilter()
bool eventFilter |
QObject * |
_obj, |
QEvent * |
_event |
overrideprotected |
🔗LoadConfig()
void LoadConfig |
const tinyxml2::XMLElement * |
_pluginElem | ) |
override |
🔗LoadGrid()
Callback to retrieve existing grid. Should only be called within the render thread. If no grid is found, the grid pointer is not updated.
🔗newSnapValues
Notify that new snapping values have been set.
🔗OnMode
void OnMode |
const QString & |
_mode | ) |
slot |
[in] | _mode | New transform mode |
🔗OnSnapToGrid
🔗OnSnapUpdate
void OnSnapUpdate |
double |
_x, |
double |
_y, |
double |
_z, |
double |
_roll, |
double |
_pitch, |
double |
_yaw, |
double |
_scaleX, |
double |
_scaleY, |
double |
_scaleZ |
slot |
[in] | _x | The snapping distance along the world's x (red) axis expressed in meters. |
[in] | _y | The snapping distance along the world's y (green) axis expressed in meters. |
[in] | _z | The snapping distance along the world's z (blue) axis expressed in meters. |
[in] | _roll | The snapping distance along the entity's roll (red) axis expressed in degrees. |
[in] | _pitch | The snapping distance along the entity's pitch (green) axis expressed in degrees. |
[in] | _yaw | The snapping distance along the entity's yaw (blue) axis expressed in degrees. |
[in] | _scaleX | The snapping scale along the entity's x (red) axis |
[in] | _scaleY | The snapping scale along the entity's y (green) axis |
[in] | _scaleZ | The snapping scale along the entity's z (blue) axis |
🔗pitchSnap
- Returns
- The set pitch rotational snapping value
🔗rollSnap
- Returns
- The set roll rotational snapping value
🔗scaleXSnap
- Returns
- The set x scaling snapping value
🔗scaleYSnap
- Returns
- The set y scaling snapping value
🔗scaleZSnap
- Returns
- The set z scaling snapping value
🔗SnapToGrid()
Sets the custom snap values to the grid values.
🔗xSnap
- Returns
- The set x translational snapping value
🔗yawSnap
- Returns
- The set yaw rotational snapping value
🔗ySnap
- Returns
- The set y translational snapping value
🔗zSnap
- Returns
- The set z translational snapping value
