Base class for all components. More...
#include <Component.hh>
BaseComponent ()=default | |
Default constructor. More... | |
virtual | ~BaseComponent ()=default |
Default destructor. More... | |
virtual std::unique_ptr< BaseComponent > | Clone ()=0 |
Clone the component. More... | |
virtual void | Deserialize (std::istream &_in) |
Fills a component based on a stream with a serialized data. By default, it will do nothing. Derived classes should override this function to support deserialization. More... | |
virtual void | Serialize (std::ostream &_out) const |
Fills a stream with a serialized version of the component. By default, it will leave the stream empty. Derived classes should override this function to support serialization. More... | |
virtual ComponentTypeId | TypeId () const =0 |
Returns the unique ID for the component's type. The ID is derived from the name that is manually chosen during the Factory registration and is guaranteed to be the same across compilers and runs. More... | |
◆ BaseComponent()
default |
◆ ~BaseComponent()
virtualdefault |
Default destructor.
◆ Clone()
pure virtual |
- Returns
- A pointer to the component.
Implemented in Component< NoData, Identifier, Serializer >, and Component< DataType, Identifier, Serializer >.
◆ Deserialize()
inlinevirtual |
[in] _in In stream.
Reimplemented in Component< NoData, Identifier, Serializer >, and Component< DataType, Identifier, Serializer >.
References std::endl(), and ignwarn.
◆ Serialize()
inlinevirtual |
[in] _out Out stream.
◆ TypeId()
pure virtual |
Referenced by Factory::New().
