gz::sim::traits Namespace Reference
Classes | |
| class | HasGazeboConvert |
| Type trait that determines if a convert from In to Out is defined. Usage: More... | |
| class | IsInStreamable |
Type trait that determines if a operator>> is defined on Stream and DataType, i.e, it checks if the function Stream& operator>>(Stream&, DataType&) exists. Example: More... | |
| class | IsOutStreamable |
Type trait that determines if a operator<< is defined on Stream and DataType, i.e, it checks if the function Stream& operator<<(Stream&, const DataType&) exists. Example: More... | |
| struct | IsSharedPtr |
| Helper trait to determine if a type is shared_ptr or not. More... | |
| struct | IsSharedPtr< std::shared_ptr< T > > |
