Tsa.hh
2  * Copyright (C) 2022 Open Source Robotics Foundation
17
19 #ifndef THREAD_SAFETY_ANALYSIS_MUTEX_H
20 #define THREAD_SAFETY_ANALYSIS_MUTEX_H
21
22 // Enable thread safety attributes only with clang.
23 // The attributes can be safely erased when compiling with other compilers.
24 #if defined(__clang__) && (!defined(SWIG))
25 #define THREAD_ANNOTATION_ATTRIBUTE__(x) __attribute__((x))
26 #else
27 #define THREAD_ANNOTATION_ATTRIBUTE__(x) // no-op
28 #endif
29
30 #define CAPABILITY(x) \
31  THREAD_ANNOTATION_ATTRIBUTE__(capability(x))
32
33 #define SCOPED_CAPABILITY \
34  THREAD_ANNOTATION_ATTRIBUTE__(scoped_lockable)
35
36 #define GUARDED_BY(x) \
37  THREAD_ANNOTATION_ATTRIBUTE__(guarded_by(x))
38
39 #define PT_GUARDED_BY(x) \
40  THREAD_ANNOTATION_ATTRIBUTE__(pt_guarded_by(x))
41
42 #define ACQUIRED_BEFORE(...) \
43  THREAD_ANNOTATION_ATTRIBUTE__(acquired_before(__VA_ARGS__))
44
45 #define ACQUIRED_AFTER(...) \
46  THREAD_ANNOTATION_ATTRIBUTE__(acquired_after(__VA_ARGS__))
47
48 #define REQUIRES(...) \
49  THREAD_ANNOTATION_ATTRIBUTE__(requires_capability(__VA_ARGS__))
50
51 #define REQUIRES_SHARED(...) \
52  THREAD_ANNOTATION_ATTRIBUTE__(requires_shared_capability(__VA_ARGS__))
53
54 #define ACQUIRE(...) \
55  THREAD_ANNOTATION_ATTRIBUTE__(acquire_capability(__VA_ARGS__))
56
57 #define ACQUIRE_SHARED(...) \
58  THREAD_ANNOTATION_ATTRIBUTE__(acquire_shared_capability(__VA_ARGS__))
59
60 #define RELEASE(...) \
61  THREAD_ANNOTATION_ATTRIBUTE__(release_capability(__VA_ARGS__))
62
63 #define RELEASE_SHARED(...) \
64  THREAD_ANNOTATION_ATTRIBUTE__(release_shared_capability(__VA_ARGS__))
65
66 #define RELEASE_GENERIC(...) \
67  THREAD_ANNOTATION_ATTRIBUTE__(release_generic_capability(__VA_ARGS__))
68
69 #define TRY_ACQUIRE(...) \
70  THREAD_ANNOTATION_ATTRIBUTE__(try_acquire_capability(__VA_ARGS__))
71
72 #define TRY_ACQUIRE_SHARED(...) \
73  THREAD_ANNOTATION_ATTRIBUTE__(try_acquire_shared_capability(__VA_ARGS__))
74
75 #define EXCLUDES(...) \
76  THREAD_ANNOTATION_ATTRIBUTE__(locks_excluded(__VA_ARGS__))
77
78 #define ASSERT_CAPABILITY(x) \
79  THREAD_ANNOTATION_ATTRIBUTE__(assert_capability(x))
80
81 #define ASSERT_SHARED_CAPABILITY(x) \
82  THREAD_ANNOTATION_ATTRIBUTE__(assert_shared_capability(x))
83
84 #define RETURN_CAPABILITY(x) \
85  THREAD_ANNOTATION_ATTRIBUTE__(lock_returned(x))
86
87 #define NO_THREAD_SAFETY_ANALYSIS \
88  THREAD_ANNOTATION_ATTRIBUTE__(no_thread_safety_analysis)
89
90
91 #ifdef USE_LOCK_STYLE_THREAD_SAFETY_ATTRIBUTES
92 // The original version of thread safety analysis the following attribute
93 // definitions. These use a lock-based terminology. They are still in use
94 // by existing thread safety code, and will continue to be supported.
95
96 // Deprecated.
97 #define PT_GUARDED_VAR \
98  THREAD_ANNOTATION_ATTRIBUTE__(pt_guarded_var)
99
100 // Deprecated.
101 #define GUARDED_VAR \
102  THREAD_ANNOTATION_ATTRIBUTE__(guarded_var)
103
104 // Replaced by REQUIRES
105 #define EXCLUSIVE_LOCKS_REQUIRED(...) \
106  THREAD_ANNOTATION_ATTRIBUTE__(exclusive_locks_required(__VA_ARGS__))
107
108 // Replaced by REQUIRES_SHARED
109 #define SHARED_LOCKS_REQUIRED(...) \
110  THREAD_ANNOTATION_ATTRIBUTE__(shared_locks_required(__VA_ARGS__))
111
112 // Replaced by CAPABILITY
113 #define LOCKABLE \
114  THREAD_ANNOTATION_ATTRIBUTE__(lockable)
115
116 // Replaced by SCOPED_CAPABILITY
117 #define SCOPED_LOCKABLE \
118  THREAD_ANNOTATION_ATTRIBUTE__(scoped_lockable)
119
120 // Replaced by ACQUIRE
121 #define EXCLUSIVE_LOCK_FUNCTION(...) \
122  THREAD_ANNOTATION_ATTRIBUTE__(exclusive_lock_function(__VA_ARGS__))
123
124 // Replaced by ACQUIRE_SHARED
125 #define SHARED_LOCK_FUNCTION(...) \
126  THREAD_ANNOTATION_ATTRIBUTE__(shared_lock_function(__VA_ARGS__))
127
128 // Replaced by RELEASE and RELEASE_SHARED
129 #define UNLOCK_FUNCTION(...) \
130  THREAD_ANNOTATION_ATTRIBUTE__(unlock_function(__VA_ARGS__))
131
132 // Replaced by TRY_ACQUIRE
133 #define EXCLUSIVE_TRYLOCK_FUNCTION(...) \
134  THREAD_ANNOTATION_ATTRIBUTE__(exclusive_trylock_function(__VA_ARGS__))
135
136 // Replaced by TRY_ACQUIRE_SHARED
137 #define SHARED_TRYLOCK_FUNCTION(...) \
138  THREAD_ANNOTATION_ATTRIBUTE__(shared_trylock_function(__VA_ARGS__))
139
140 // Replaced by ASSERT_CAPABILITY
141 #define ASSERT_EXCLUSIVE_LOCK(...) \
142  THREAD_ANNOTATION_ATTRIBUTE__(assert_exclusive_lock(__VA_ARGS__))
143
144 // Replaced by ASSERT_SHARED_CAPABILITY
145 #define ASSERT_SHARED_LOCK(...) \
146  THREAD_ANNOTATION_ATTRIBUTE__(assert_shared_lock(__VA_ARGS__))
147
148 // Replaced by EXCLUDE_CAPABILITY.
149 #define LOCKS_EXCLUDED(...) \
150  THREAD_ANNOTATION_ATTRIBUTE__(locks_excluded(__VA_ARGS__))
151
152 // Replaced by RETURN_CAPABILITY
153 #define LOCK_RETURNED(x) \
154  THREAD_ANNOTATION_ATTRIBUTE__(lock_returned(x))
155
156 #endif // USE_LOCK_STYLE_THREAD_SAFETY_ATTRIBUTES
157
158 #endif
