Model Photo Shoot
Using the Model Photo Shoot plugin
Gazebo offers a model photo taking tool that will take perspective, top, front, and both sides pictures of a model. You can test the demo world in Gazebo, located at examples/worlds/model_photo_shoot.sdf, by running the following command:
gz sim -s -r -v 4 --iterations 50 model_photo_shoot.sdf
This will start Gazebo server, load the model and the plugin, take the pictures and shutdown after 50 iterations. The pictures can be found at the same location where the command was issued.
Model Photo Shoot configurations
SDF is used to load and configure the Model Photo Shoot plugin. The demo SDF contains a good example of the different options and other related plugins:
  1. The physics plugin:
filename="gz-sim-physics-system"
name="gz::sim::systems::Physics">
A physics plugin is needed only if the <random_joints_pose> option is to be used. This will allow the Model Photo Shoot plugin to set the joints to random positions.
  1. The render engine plugin:
filename="gz-sim-sensors-system"
name="gz::sim::systems::Sensors">
<render_engine>ogre2</render_engine>
<background_color>1, 1, 1</background_color>
A render plugin is needed to render the image. If ogre2 is used, as shown in the example, the <backgrond_color> tag can be used to set the background of the pictures taken by the plugin. Please note that lights added by the plugin will also affect the final resulting background color on the images.
  1. The model and the photo shoot plugin:
<uri>https://fuel.gazebosim.org/1.0/OpenRobotics/models/Robonaut</uri>
filename="gz-sim-model-photo-shoot-system"
name="gz::sim::systems::ModelPhotoShoot">
<translation_data_file>poses.txt</translation_data_file>
<random_joints_pose>true</random_joints_pose>
The model is loaded through the <uri> tag. Then the model photo shoot plugin and its options are specified:
  • <translation_data_file>: (optional) Location to store the camera translation, scaling data and joints position (if using the <random_joints_pose> option) that can be used to replicate the pictures using other systems.
  • <random_joints_pose>: (optional) When set to true the joints in the model will be set to random positions prior to taking the pictures.
  1. Camera sensor:
<model name="photo_shoot">
<pose>0 0 0 0 0 0</pose>
<sensor name="camera" type="camera">
<width>960</width>
<height>540</height>
<far>100</far>
<topic>camera</topic>
A camera sensor must be added as it will be used by the plugin to take the pictures. This allows plugin users to set the different parameters of the camera to their desired values.
