Source Installation on Ubuntu#
These instructions apply to Ubuntu Noble (24.04).
Install tools#
The use of some additional tools is recommended to help with the source compilation, although other ways of correctly getting and building the sources are also possible.
The easiest way to get the sources of all libraries is to use vcstool.
To compile all the different libraries and gz-sim in the right order colcon is recommended. The colcon tool is available on all platforms using pip (or pip3, if pip fails).
Some tools require Python 3.5 (or higher) which is not the default option on some platforms (like Ubuntu Focal). The Python virtualenv could be a useful solution in cases where the default option cannot be easily changed.
Generic tools#
Install tools needed by this tutorial:
sudo apt update && sudo apt install -y python3-pip python3-venv lsb-release gnupg curl git
vcstool and colcon from pip#
PIP is available on all platforms. Using a PIP workspace to install the tools:
python3 -m venv $HOME/vcs_colcon_installation
. $HOME/vcs_colcon_installation/bin/activate
pip3 install vcstool colcon-common-extensions
vcs and colcon are now available from the PIP workspace in the current
terminal. For using them in other terminals run the activate script as
done above.
vcstool and colcon from apt#
An alternative method is to use the .deb packages available on Debian or Ubuntu:
sudo sh -c 'echo "deb http://packages.ros.org/ros2/ubuntu $(lsb_release -sc) main" > /etc/apt/sources.list.d/ros2-latest.list'
curl -s https://raw.githubusercontent.com/ros/rosdistro/master/ros.asc | sudo apt-key add -
sudo apt-get update
sudo apt-get install python3-vcstool python3-colcon-common-extensions
Getting the sources#
The instructions below use some UNIX commands to manage directories but the equivalent alternatives on Windows should provide the same result.
The first step is to create a developer workspace in which vcstool and
colcon can work:
mkdir -p ~/workspace/src
cd ~/workspace/
Use vcstool to automatically retrieve all the Gazebo libraries sources from
their repositories:
vcs import --input https://raw.githubusercontent.com/gazebo-tooling/gazebodistro/master/collection-jetty.yaml src
The src subdirectory should contain all the sources ready to be built.
Install dependencies#
Before compiling it is necessary to install all the dependencies of the different packages that compose the Jetty collection. Every platform has a different method to install software dependencies.
Add packages.osrfoundation.org to the apt sources list:
sudo curl https://packages.osrfoundation.org/gazebo.gpg --output /usr/share/keyrings/pkgs-osrf-archive-keyring.gpg
echo "deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/pkgs-osrf-archive-keyring.gpg] http://packages.osrfoundation.org/gazebo/ubuntu-stable $(lsb_release -cs) main" | sudo tee /etc/apt/sources.list.d/gazebo-stable.list > /dev/null
sudo apt-get update
The command below must be run from a workspace with the Gazebo source code and will install all dependencies in Ubuntu:
cd ~/workspace/src
sudo apt -y install \
$(sort -u $(find . -iname 'packages-'`lsb_release -cs`'.apt' -o -iname 'packages.apt' | grep -v '/\.git/') | sed '/gz\|sdf/d' | tr '\n' ' ')
Alternatively, if you want to install dependencies using rosdep, ensure that rosdep is installed and use the following command:
cd ~/workspace/src
rosdep install -i --from-path . -y \
--skip-keys "gz-cmake3 DART libogre-dev libogre-next-2.3-dev"
The rosdep command attempts to install dependencies listed in package.xml
files, but when problems arise the --skip-keys argument is used. Explanations
for its use in the previous line are given below:
gz-cmake3:gz-tools2can build from source against any ofgz-cmake3,gz-cmake4, andgz-cmake(v5), and this workspace only containsgz-cmake(v5). Thegz-tools2package.xmlfile only depends on gz-cmake3 and since that package is not present, use--skip-keys gz-cmake3.DART:gz-physicscan build against dartsim, which is listed as DART in the gz-physics package.xml file. This package is not in the workspace, soDARTis added to the--skip-keysstring. See the discussion in gz-physics#608 for more background on the package name used forDART.libogre-devandlibogre-next-2.3-dev:gz-renderingcan build against ogre 1.9 and ogre-next 2.3. The debian package names are listed as dependencies in the gz-rendering package.xml but they are not available on all Linux versions, so work around with--skip-keys "libogre-dev libogre-next-2.3-dev".
Building the Gazebo Libraries#
Once the compiler and all the sources are in place it is time to compile them.
Start the procedure by changing into the workspace and listing the packages
recognized by colcon:
cd ~/workspace/
colcon graph
colcon graph should list the Gazebo libraries with an
interdependency diagram.
If that is the case, then you are ready
to build the whole set of libraries:
Warning
Compilation can take up to 16GB of RAM memory. To disable parallel compilation threads and reduce RAM usage,
run export CMAKE_BUILD_PARALLEL_LEVEL=1 beforehand (source), and add --executor sequential to the colcon build commands below
(source).
colcon build --merge-install
To speed up the build process, you could also disable tests by using
colcon build --cmake-args ' -DBUILD_TESTING=OFF' --merge-install
To use debuggers activate debug symbols. Gazebo will run slower, but you’ll be able to use GDB:
colcon build --cmake-args ' -DBUILD_TESTING=OFF' ' -DCMAKE_BUILD_TYPE=Debug' --merge-install
To build a specific package with all its dependent packages:
colcon build --merge-install --packages-up-to PACKAGE_NAME
To build a single package:
colcon build --packages-select PACKAGE_NAME
Visit colcon documentation to view more colcon build and test options.
If there are no errors, all the binaries should be ready to use. You can check the Troubleshooting section for errors.
Using the workspace#
The workspace needs to be sourced every time a new terminal is used.
Run the following command to source the workspace in bash:
. ~/workspace/install/setup.bash
Or in zsh:
. ~/workspace/install/setup.zsh
This is the end of the source install instructions; head back to the Getting started page to start using Gazebo!
Uninstalling source-based install#
A source-based install can be “uninstalled” using several methods, depending on the results you want:
If you installed your workspace with
colconas instructed above, “uninstalling” could be just a matter of opening a new terminal and not sourcing the workspace’ssetup.sh. This way, your environment will behave as though Gazebo is not installed on your system.If, in addition to not wanting to use the libraries, you’re also trying to free up space, you can delete the entire workspace directory with:
rm -rf ~/workspace
If you want to keep the source code, you can remove the
install/build/logdirectories as desired, leaving thesrcdirectory.
Troubleshooting#
See Troubleshooting
QML Debugging#
To perform QML debugging you’ll need:
Add
--cmake-args -DDQT_QML_DEBUGflag to colconQtCreator
You will need to build Gazebo with:
colcon build --cmake-args ' -DQT_QML_DEBUG' --merge-install
Note: Advanced users may note that only the
gz-simproject needs this flag.
After that’s done, launching gz sim -g will result in the following message:
QML debugging is enabled. Only use this in a safe environment.
QML Debugger: Waiting for connection on port 40000...
After that you can just head to
QtCreator -> Debug -> Start Debugging -> Attach to QML Port...
and enter the QML port
Once you click there, set the port number to 40000 and hit ok
We’re working to improve QtCreator integration so that it works out of the box.
The ruby gz script doesn’t yet pass the necessary command line arguments to the application.
Note that because all instances will try to use port 40000, only one instance can use it. If you shutdown the process and restart it immediately too quickly, the OS may still claim the port is in use and hence the 2nd (re)launch will not listen to QML debugger attach requests.
Avoid QML stall waiting for debugger on startup#
During development, you may find troublesome that gz sim -g won’t actually start until
QtCreator hooks to the QML Debugging port.
If that’s a problem, you can edit the C++ file gz-sim/src/cmd/gz.cc and remove block
from it. E.g.
// The following:
const_cast<char *>(
"-qmljsdebugger=port:40000,block,services:DebugMessages,QmlDebugger,"
"V8Debugger,QmlInspector,DebugTranslation")
// Must become the following
const_cast<char *>(
"-qmljsdebugger=port:40000,services:DebugMessages,QmlDebugger,"
