BaseStoreWrapper< T, U > Class Template Reference
#include <BaseStorage.hh>
 BaseStoreWrapper (UStorePtr _store)
virtual ~BaseStoreWrapper ()
virtual void DestroyAll ()
virtual void RemoveAll ()
- Public Member Functions inherited from StoreWrapper< T, U >
virtual ~StoreWrapper ()
virtual ~Store ()
UStorePtr store
◆ BaseStoreWrapper()
BaseStoreWrapper ( UStorePtr  _store)
◆ ~BaseStoreWrapper()
~BaseStoreWrapper
◆ Add()
bool Add ( TPtr  _object)
True if successful
Implements Store< T >.
◆ Contains()
◆ ContainsId()
◆ ContainsName()
void Destroy ( TPtr  _object)
◆ DestroyAll()
void DestroyAll ( )
◆ DestroyById()
◆ DestroyByIndex()
◆ DestroyByName()
◆ GetById()
BaseStoreWrapper< T, U >::TPtr GetById ( unsigned int  _id) const
The specified element
◆ GetByIndex()
BaseStoreWrapper< T, U >::TPtr GetByIndex ( unsigned int  _index) const
◆ GetByName()
BaseStoreWrapper< T, U >::TPtr GetByName ( const std::string &  _name) const
◆ Remove()
BaseStoreWrapper< T, U >::TPtr Remove ( TPtr  _object)
The removed element
◆ RemoveAll()
void RemoveAll ( )
◆ RemoveById()
BaseStoreWrapper< T, U >::TPtr RemoveById ( unsigned int  _id)
The removed element
◆ RemoveByIndex()
BaseStoreWrapper< T, U >::TPtr RemoveByIndex ( unsigned int  _index)
The removed element
◆ RemoveByName()
BaseStoreWrapper< T, U >::TPtr RemoveByName ( const std::string &  _name)
The removed element
◆ Size()
unsigned int Size ( ) const
◆ store
UStorePtr store
