Ogre2 render engine class. A singleton class that manages the underlying ogre2 render engine, loads its plugins, and creates resources needed for the engine to run. More...
#include <Ogre2RenderEngine.hh>
virtual ~Ogre2RenderEngine ()
void AddResourcePath (const std::string &_uri) override
 Add path to resourcea in ogre2's resource manager. More...
std::string CreateRenderWindow (const std::string &_handle, const unsigned int _width, const unsigned int _height, const double _ratio, const unsigned int _antiAliasing)
std::vector< unsigned int > FSAALevels () const
 Get a list of all supported FSAA levels for this render system. More...
virtual Ogre::Root * OgreRoot () const
 Get the ogre2 root object. More...
Ogre::v1::OverlaySystem * OverlaySystem () const
- Public Member Functions inherited from BaseRenderEngine
virtual ~BaseRenderEngine ()
virtual ScenePtr CreateScene (const std::string &_name) override
virtual ScenePtr CreateScene (unsigned int _id, const std::string &_name) override
virtual void DestroyScene (ScenePtr _scene) override
virtual void DestroySceneById (unsigned int _id) override
virtual void DestroySceneByIndex (unsigned int _index) override
virtual void DestroySceneByName (const std::string &_name) override
virtual void DestroyScenes () override
virtual bool Fini () override
virtual bool HasScene (ConstScenePtr _scene) const override
virtual bool HasSceneId (unsigned int _id) const override
virtual bool HasSceneName (const std::string &_name) const override
virtual bool Init () override
virtual bool IsInitialized () const override
virtual bool IsLoaded () const override
virtual bool Load (const std::map< std::string, std::string > &_params={}) override
virtual RenderPassSystemPtr RenderPassSystem () const override
virtual ScenePtr SceneById (unsigned int _id) const override
virtual ScenePtr SceneByIndex (unsigned int _index) const override
virtual ScenePtr SceneByName (const std::string &_name) const override
virtual unsigned int SceneCount () const override
- Public Member Functions inherited from RenderEngine
virtual ~RenderEngine ()
virtual ScenePtr CreateSceneImpl (unsigned int _id, const std::string &_name) override
 Create a scene. More...
virtual bool InitImpl () override
 Initialize the render engine. More...
virtual bool LoadImpl (const std::map< std::string, std::string > &_params) override
 Engine implementation of Load function. More...
virtual SceneStorePtr Scenes () const override
 Get a pointer to the list of scenes managed by the render engine. More...
- Protected Member Functions inherited from BaseRenderEngine
 BaseRenderEngine ()
virtual unsigned int NextSceneId ()
virtual void PrepareScene (ScenePtr _scene)
- Protected Member Functions inherited from SingletonT< Ogre2RenderEngine >
 SingletonT ()
virtual ~SingletonT ()
- Static Public Member Functions inherited from SingletonT< Ogre2RenderEngine >
static T * Instance ()
- Protected Attributes inherited from BaseRenderEngine
bool initialized = false
bool loaded = false
unsigned int nextSceneId
RenderPassSystemPtr renderPassSystem
 Render pass system for this render engine. More...
std::vector< std::string > resourcePaths
 a list of paths that render engines use to locate their resources More...
◆ ~Ogre2RenderEngine()
virtual ~Ogre2RenderEngine ( )
◆ AddResourcePath()
void AddResourcePath ( const std::string &  _uri)
[in]_uriReousrce path in the form of an uri
Reimplemented from BaseRenderEngine.
◆ CreateRenderWindow()
std::string CreateRenderWindow ( const std::string &  _handle,
[in]_handleHandle of native window which the render window will attach
[in]_widthWidth of render window
[in]_heightHeight of render window
[in]_ratioDevice pixel ratio (typically needed for retina displays)
[in]_antiAliasingAnti-aliasing level
◆ CreateSceneImpl()
virtual ScenePtr CreateSceneImpl ( unsigned int  _id,
const std::string &  _name
Create a scene.
[in]_idUnique scene Id
[in]_nameName of scene
Implements BaseRenderEngine.
True if the render-engine was successfully destroyed
◆ FSAALevels()
std::vector<unsigned int> FSAALevels ( ) const
a list of FSAA levels
◆ InitImpl()
virtual bool InitImpl ( )
True if the operation is successful
◆ IsEnabled()
◆ LoadImpl()
virtual bool LoadImpl ( const std::map< std::string, std::string > &  _params)
◆ Name()
The render-engine name
Implements RenderEngine.
◆ OgreRoot()
virtual Ogre::Root* OgreRoot ( ) const
ogre2 root object
◆ OverlaySystem()
Ogre::v1::OverlaySystem* OverlaySystem ( ) const
◆ Scenes()
virtual SceneStorePtr Scenes ( ) const
list of scenes
