Ogre2.x implementation of a submesh store factory class. More...
#include <Ogre2MeshFactory.hh>
 Ogre2SubMeshStoreFactory (Ogre2ScenePtr _scene, Ogre::Item *_item)
virtual ~Ogre2SubMeshStoreFactory ()
virtual Ogre2SubMeshStorePtr Create ()
 Create the submeshes. More...
virtual void CreateNameList ()
 Create a list of names and the corresponding submesh object. More...
virtual Ogre2SubMeshPtr CreateSubMesh (unsigned int _index)
 Helper function to create submesh at the given index. More...
virtual void PopulateDefaultNames ()
 Populate the name list with default generated names. More...
virtual void PopulateGivenNames ()
 Populate the name list with names associated with each ogre subitem. More...
std::vector< std::string > names
 A list of names associated with each ogre subitem / submesh. More...
Ogre::Item * ogreItem = nullptr
 Pointer to the parent ogre item. More...
 Pointer to the scene object. More...
◆ Ogre2SubMeshStoreFactory()
Ogre2SubMeshStoreFactory ( Ogre2ScenePtr  _scene,
Ogre::Item *  _item
[in]_scenePointer to the scene object
[in]_itemParent ogre item
◆ ~Ogre2SubMeshStoreFactory()
virtual ~Ogre2SubMeshStoreFactory ( )
◆ Create()
virtual Ogre2SubMeshStorePtr Create ( )
A store containing all the submeshes
◆ CreateNameList()
virtual void CreateNameList ( )
◆ CreateSubMesh()
virtual Ogre2SubMeshPtr CreateSubMesh ( unsigned int  _index)
[in]_indexIndex of the ogre subitem. The subitem is then used to create the submesh.
◆ PopulateDefaultNames()
virtual void PopulateDefaultNames ( )
◆ PopulateGivenNames()
virtual void PopulateGivenNames ( )
◆ names
std::vector<std::string> names
◆ ogreItem
Ogre::Item* ogreItem = nullptr
◆ scene
Ogre2ScenePtr scene
