#include <OgreRenderEngine.hh>
Public Types
enum  OgreRenderPathType {
  NONE = 0, VERTEX = 1, FORWARD = 2, DEFERRED = 3,
  RENDER_PATH_COUNT
 The type of rendering path used by the rendering engine. More...
virtual ~OgreRenderEngine ()
void AddResourcePath (const std::string &_uri) override
 Add path to media resource location. More...
std::string CreateRenderWindow (const std::string &_handle, const unsigned int _width, const unsigned int _height, const double _ratio, const unsigned int _antiAliasing)
std::vector< unsigned int > FSAALevels () const
 Get a list of all supported FSAA levels for this render system. More...
virtual Ogre::Root * OgreRoot () const
OgreRenderPathType RenderPathType () const
- Public Member Functions inherited from BaseRenderEngine
virtual ~BaseRenderEngine ()
virtual ScenePtr CreateScene (const std::string &_name) override
virtual ScenePtr CreateScene (unsigned int _id, const std::string &_name) override
virtual void DestroyScene (ScenePtr _scene) override
virtual void DestroySceneById (unsigned int _id) override
virtual void DestroySceneByIndex (unsigned int _index) override
virtual void DestroySceneByName (const std::string &_name) override
virtual void DestroyScenes () override
virtual bool Fini () override
virtual bool HasScene (ConstScenePtr _scene) const override
virtual bool HasSceneId (unsigned int _id) const override
virtual bool HasSceneName (const std::string &_name) const override
virtual bool Init () override
virtual bool IsInitialized () const override
virtual bool IsLoaded () const override
virtual bool Load (const std::map< std::string, std::string > &_params={}) override
virtual RenderPassSystemPtr RenderPassSystem () const override
virtual ScenePtr SceneById (unsigned int _id) const override
virtual ScenePtr SceneByIndex (unsigned int _index) const override
virtual ScenePtr SceneByName (const std::string &_name) const override
virtual unsigned int SceneCount () const override
- Public Member Functions inherited from RenderEngine
virtual ~RenderEngine ()
virtual ScenePtr CreateSceneImpl (unsigned int _id, const std::string &_name) override
virtual bool InitImpl () override
virtual bool LoadImpl (const std::map< std::string, std::string > &_params) override
 Engine implementation of Load function. More...
virtual SceneStorePtr Scenes () const override
- Protected Member Functions inherited from BaseRenderEngine
 BaseRenderEngine ()
virtual unsigned int NextSceneId ()
virtual void PrepareScene (ScenePtr _scene)
- Protected Member Functions inherited from SingletonT< OgreRenderEngine >
 SingletonT ()
virtual ~SingletonT ()
- Static Public Member Functions inherited from SingletonT< OgreRenderEngine >
static T * Instance ()
- Protected Attributes inherited from BaseRenderEngine
bool initialized = false
bool loaded = false
unsigned int nextSceneId
RenderPassSystemPtr renderPassSystem
 Render pass system for this render engine. More...
std::vector< std::string > resourcePaths
 a list of paths that render engines use to locate their resources More...
◆ OgreRenderPathType
Enumerator
NONE
No rendering is done.
VERTEX
Most basic rendering, with least fidelity.
FORWARD
Utilizes the RTT shader system.
DEFERRED
Utilizes deferred rendering. Best fidelity.
RENDER_PATH_COUNT
Count of the rendering path enums.
◆ ~OgreRenderEngine()
virtual ~OgreRenderEngine ( )
◆ AddResourcePath()
void AddResourcePath ( const std::string &  _path)
[in]_pathAbsolute path to resource location
Reimplemented from BaseRenderEngine.
◆ CreateRenderWindow()
std::string CreateRenderWindow ( const std::string &  _handle,
◆ CreateSceneImpl()
virtual ScenePtr CreateSceneImpl ( unsigned int  _id,
const std::string &  _name
Implements BaseRenderEngine.
True if the render-engine was successfully destroyed
◆ FSAALevels()
std::vector<unsigned int> FSAALevels ( ) const
a list of FSAA levels
◆ InitImpl()
virtual bool InitImpl ( )
◆ IsEnabled()
◆ LoadImpl()
virtual bool LoadImpl ( const std::map< std::string, std::string > &  _params)
[in]_paramsParameters to be passed to the render engine. Current accepts the following parameters and values: "useCurrentGLContext" : "1" or "0". Use current OpenGL context for rendering
◆ Name()
The render-engine name
Implements RenderEngine.
◆ OgreRoot()
virtual Ogre::Root* OgreRoot ( ) const
◆ RenderPathType()
OgreRenderPathType RenderPathType ( ) const
◆ Scenes()
virtual SceneStorePtr Scenes ( ) const
