ShaderParam Class Reference
a variant type that holds params that can be passed to a shader More...
#include <ShaderParam.hh>
Public Types
enum  ParamType : uint16_t { PARAM_NONE = 0, PARAM_FLOAT = 1, PARAM_INT = 2 }
 ShaderParam ()
 constructor More...
 ShaderParam (const ShaderParam &_other)
 copy constructor More...
 ~ShaderParam ()
 destructor More...
void operator= (const float _value)
 Set this to be a float param. More...
void operator= (const int _value)
 Set this to be an integer param;. More...
ShaderParam & operator= (const ShaderParam &_other)
 Set from another ShaderParam. More...
ParamType Type () const
 Get the type of this parameter. More...
bool Value (float *_value) const
 Get the value of this parameter if it is a float. More...
bool Value (int *_value) const
 Get the value of this parameter if it is an int. More...
◆ ParamType
Enumerator
PARAM_NONE
Type none.
PARAM_FLOAT
Float type param.
PARAM_INT
Integer type param.
◆ ShaderParam() [1/2]
constructor
◆ ShaderParam() [2/2]
ShaderParam ( const ShaderParam &  _other)
copy constructor
[in]_otherAnother ShaderParam
◆ ~ShaderParam()
destructor
◆ operator=() [1/3]
void operator= ( const float  _value)
[in]_valueValue to set this param to.
◆ operator=() [2/3]
void operator= ( const int  _value)
◆ operator=() [3/3]
ShaderParam& operator= ( const ShaderParam &  _other)
[in]_otherAnother ShaderParam.
Reference to this ShaderParam.
◆ Type()
ParamType Type ( ) const
Type of this parameter
◆ Value() [1/2]
bool Value ( float *  _value) const
[out]_valuevariable the value will be copied to
true if the param is the expected type
◆ Value() [2/2]
bool Value ( int *  _value) const
