gz/rendering/DepthCamera.hh
17 #ifndef GZ_RENDERING_DEPTHCAMERA_HH_
18 #define GZ_RENDERING_DEPTHCAMERA_HH_
20 #include <string>
21
22 #include <gz/common/Event.hh>
23 #include "gz/rendering/Camera.hh"
24
25 namespace ignition
26 {
27  namespace rendering
28  {
29  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
34  class IGNITION_RENDERING_VISIBLE DepthCamera :
35  public virtual Camera
36  {
38  public: typedef std::function<void(const void*, unsigned int,
39  unsigned int, unsigned int, const std::string&)> NewFrameListener;
40
42  public: virtual ~DepthCamera() { }
43
45  public: virtual void CreateDepthTexture() = 0;
46
49  public: virtual const float *DepthData() const = 0;
50
54  public: virtual gz::common::ConnectionPtr ConnectNewDepthFrame(
55  std::function<void(const float *, unsigned int, unsigned int,
56  unsigned int, const std::string &)> _subscriber) = 0;
57
74  public: virtual gz::common::ConnectionPtr ConnectNewRgbPointCloud(
75  std::function<void(const float *_pointCloud, unsigned int _width,
76  unsigned int _height, unsigned int _depth,
77  const std::string &_format)> _subscriber) = 0;
78  };
79  }
80  }
81 }
82 #endif
virtual gz::common::ConnectionPtr ConnectNewDepthFrame(std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber)=0
Connect to the new depth image signal.
STL class.
Definition: gz/rendering/DepthCamera.hh:34
Definition: gz/rendering/Camera.hh:40
virtual const float * DepthData() const =0
All things needed to get back z buffer for depth data.
virtual gz::common::ConnectionPtr ConnectNewRgbPointCloud(std::function< void(const float *_pointCloud, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &_format)> _subscriber)=0
Connect to the new rgb point cloud signal.
virtual void CreateDepthTexture()=0
Create a texture which will hold the depth data.
std::function< void(const void *, unsigned int, unsigned int, unsigned int, const std::string &)> NewFrameListener
Definition: gz/rendering/DepthCamera.hh:39
Definition: gz/rendering/DepthCamera.hh:42
