gz/rendering/PixelFormat.hh
17 #ifndef GZ_RENDERING_PIXELFORMAT_HH_
18 #define GZ_RENDERING_PIXELFORMAT_HH_
20 #include <string>
21 #include "gz/rendering/config.hh"
22 #include "gz/rendering/Export.hh"
23
24 namespace ignition
25 {
26  namespace rendering
27  {
29  //
32  enum IGNITION_RENDERING_VISIBLE PixelFormat
33  {
37  PF_L8 = 1,
39  PF_R8G8B8 = 2,
41  PF_B8G8R8 = 3,
50  // Float32 format one channel
52  // Float32 format and RGB
54  // Float32 format and RGB
56  // 16 bit single channel
57  PF_L16 = 11,
61  PF_COUNT = 13
62  };
63
66  class IGNITION_RENDERING_VISIBLE PixelUtil
67  {
70  public: static bool IsValid(PixelFormat _format);
71
77  public: static PixelFormat Sanitize(PixelFormat _format);
78
82  public: static std::string Name(PixelFormat _format);
83
88  public: static unsigned int ChannelCount(PixelFormat _format);
89
94  public: static unsigned int BytesPerChannel(PixelFormat _format);
95
100  public: static unsigned int BytesPerPixel(PixelFormat _format);
101
110  public: static unsigned int MemorySize(PixelFormat _format,
111  unsigned int _width, unsigned int _height);
112
118  public: static PixelFormat Enum(const std::string &_name);
119
121  private: static const char *names[PF_COUNT];
122
124  private: static const unsigned char channelCounts[PF_COUNT];
125
127  private: static const unsigned char channelByteCounts[PF_COUNT];
128  };
129  }
130  }
131 }
132 #endif
Provides supporting functions for PixelFormat enum.
Definition: gz/rendering/PixelFormat.hh:67
Sanitize given format. If the given value is invalid, PF_UNKNOWN will be returned,...
Get human-readable name for pixel format value.
Get number of channels for given format. If an invalid format is given, 0 will be returned.
static unsigned int MemorySize(PixelFormat _format, unsigned int _width, unsigned int _height)
Get total memory size in bytes for an image with the given format and dimensions. If an invalid forma...
Determine if given format is valid PixelFormat enum.
Get number of bytes per channel for given format. If an invalid format is given, 0 will be returned.
Get number of bytes per pixel for given format. If an invalid format is given, 0 will be returned....
Get enum value by human-readable name. The given string should match watch is returned by GetName....
PixelFormat
Image pixel format types.
Definition: gz/rendering/PixelFormat.hh:33
@ PF_BAYER_GBGR8
< Bayer GBGR, 1-byte per channel
Definition: gz/rendering/PixelFormat.hh:47
@ PF_L16
Definition: gz/rendering/PixelFormat.hh:57
@ PF_B8G8R8
< BGR, 1-byte per channel
Definition: gz/rendering/PixelFormat.hh:41
@ PF_R8G8B8
< RGB, 1-byte per channel
Definition: gz/rendering/PixelFormat.hh:39
@ PF_BAYER_GRGB8
< Bayer GRGB, 1-byte per channel
Definition: gz/rendering/PixelFormat.hh:49
@ PF_BAYER_RGGB8
< Bayer RGGB, 1-byte per channel
Definition: gz/rendering/PixelFormat.hh:43
@ PF_L8
< Grayscale, 1-byte per channel
Definition: gz/rendering/PixelFormat.hh:37
@ PF_FLOAT32_RGB
Definition: gz/rendering/PixelFormat.hh:55
@ PF_BAYER_BGGR8
< Bayer BGGR, 1-byte per channel
Definition: gz/rendering/PixelFormat.hh:45
@ PF_COUNT
< Number of pixel format types
Definition: gz/rendering/PixelFormat.hh:61
@ PF_UNKNOWN
< Unknown or errant type
Definition: gz/rendering/PixelFormat.hh:35
@ PF_FLOAT32_RGBA
Definition: gz/rendering/PixelFormat.hh:53
@ PF_R8G8B8A8
< RGBA, 1-byte per channel
Definition: gz/rendering/PixelFormat.hh:59
@ PF_FLOAT32_R
Definition: gz/rendering/PixelFormat.hh:51
